Capital Culinarian Range
range switch
8 replies to this topic
#1 robrdavis
robrdavis
  • 6 posts
Posted 02 November 2012 - 09:06 AM
I have a customer who has a Capital Culinarian series range and am looking for a service manual for it. It's the 60" (seems bigger in person though!) model number GSCR48Q or GSCR486 (not sure which, I might have written it down wrong).
The left-front burner, when turned on, will not stop sparking. I've ordered a new valve/switch for it, but wasn't able to easily determine how to get into the thing while I was there last.
If anyone can point me to the manual, or an easy way into the unit, I'd lift a beer in your name. (Darn things are hard to email!)
Thanks!
Rob
#2 RegUS_PatOff
  • 30,203 posts
Posted 02 November 2012 - 12:10 PM
:whistling: $ 8,000 - $ 10,000
... Capital Culinarian series
... It's the 60"
... GSCR48Q or GSCR486
I can't find ant service on it, yet ...
1) The "Culinarian" series would have a "C" before the GSCR48 model number ...
2) GSCR48 signifies 48"
3) could be:
GSCR48__ (4G, 4W, 4QG, 6Q, 6G, 8)
GSCR60__ (4QG,4QW, 4GW, 6QG, 6G, 6W)
#3 robrdavis
robrdavis
  • 6 posts
Posted 02 November 2012 - 12:14 PM
Its the gscr48q. I guess it just felt like a 60 when I pulled it away from the wall at the ens of a long day. This bugger is heavy!
#4 RegUS_PatOff
  • 30,203 posts
Posted 02 November 2012 - 12:31 PM
... Its the gscr48q
still seems like there's a character missing
#5 robrdavis
robrdavis
  • 6 posts
Posted 02 November 2012 - 12:43 PM
There's "nat" after it, but it was crossed out and "lp" written on after it was converted.
#6 RegUS_PatOff
  • 30,203 posts
Posted 02 November 2012 - 01:28 PM
GSCR484G
GSCR484W
GSCR484QG
GSCR486Q
GSCR486G
GSCR488
#7 robrdavis
robrdavis
  • 6 posts
Posted 02 November 2012 - 11:10 PM
Heh. Nope. None of the above. I was looking at the label when I posted last.
I'd also sent an email to Capital requesting the manual, but when they got back to me, they said that even they don't have a service manual for it. The best they could do was send me an exploded view (which I can post here if anyone's interested and I can figure out how).
Thanks for the effort Reg. I do appreciate it. Alas, I wasn't able to make it to the store to restock on beer today, so you'll have to settle for a toast with a rum and Coke!
Edited by robrdavis, 02 November 2012 - 11:11 PM.
#8 RegUS_PatOff
  • 30,203 posts
Posted 03 November 2012 - 04:36 AM
... exploded view (which I can post here if anyone's interested and I can figure out how).
... you'll have to settle for a toast with a rum and Coke!
1) that would be nice (if anyone else runs into a Capital)
2) that'll work Posted Image :pint1:
#9 Budget Appliance Repair
  • 3,998 posts
Posted 03 November 2012 - 05:49 AM
I don't know anything about these ranges but I really doubt the valve or switch is bad.
This most likely uses the spark module with re-ignite meaning that anytime you turn any switch on it will send power to the spark module at all times for any on position of the valve, the module sense the flame at the burner and stops sparking. If the flame goes out for any reason the spark module will start sparking again to re-light the burner. When changing out a spark module you must be careful to make sure all wiring is attached properly, (each burner will have it's one switch input and spark output, if you get any of the wires swapped around it would cause your problem but it would be on multiple burners).
Grounding problems with the burner that won't stop sparking or ignitor broken or out of position so not in the flame correctly when burner lights or a bad module will cause this problem.
William Burk (Willie)
Eureka, CA 95501
