Whirlpool Range Model #WFG361LVS
#1
Posted 06 November 2012 - 08:20 PM
It has an electrode spark ignition.
Sometimes it sparks once and lights right up. The next time it won't.
Is there anything else that consistently fires this ignitor?
Or does it just sound like a tired igniter?
Bruce
#2
Posted 06 November 2012 - 08:40 PM
maybe this will help...your oven should have an igniter like on the video...the electrodes are on the burners and not used for "bake"
If the name David Mabry rings a bell he is my hvac/r intstructo
#3
Posted 06 November 2012 - 09:45 PM
Check this out...
http://www.repaircli...d697207b5a13c40
That's the part that lights the oven Bake.
Maybe you've not seen this before, they're not what I usually see either.
#4
Posted 06 November 2012 - 09:49 PM
1) tech sheet depends on missing last digit of model number... WFG361LVS
... Oven Bake is intermittent.
... It has an electrode spark ignition
2) Has this Oven worked OK up till now at this location ?
Any Household new wiring or connections ?
Check for proper Wall Outlet polarity and ground
#5
Posted 06 November 2012 - 10:00 PM
#6
Posted 06 November 2012 - 10:30 PM
#7
Posted 06 November 2012 - 11:50 PM
#8
Posted 07 November 2012 - 12:08 AM
Order the lower burner with electrode. Should take care of it.
http://www.repaircli...8191123/1177024
#9
Posted 07 November 2012 - 12:31 AM
Electrode is available separately.
REG US
This unit has worked fine where it is. Nothing changed. No electrical work done. Broiler works fine. Surface units work fine.
#10
Posted 07 November 2012 - 12:34 AM
#11
Posted 07 November 2012 - 05:52 AM
Visually check the stregth of the broil spark as you turn the oven on for bake (both spark at the same time). Symptoms described above could indicate a bad (weak) spark module.
Mother Teresa
#12
Posted 07 November 2012 - 06:52 AM
... tech sheet depends on missing last digit of model number
... Check for proper Wall Outlet polarity and ground
- kdog and Chat_in_FL like this
