GE Refrigerator Model #PSC23SGRC-SS
3 replies to this topic
#1 bogreen
bogreen
    Kohai
  • 387 posts
Posted 07 November 2012 - 10:13 PM
Hi,
I'm going to look at this refrigerator on Friday.
Thought I'd solicit ideas from you wonderful techs before I get there, so I can
maybe arrive with the part needed to get the job done in one trip, which isn't happening much
these days.
The customer says the dispensers stopped working last week and now the whole display
has gone dead.
I know it's probably the dispenser board, but it also has one of the common motherboards
on the back and I know alot goes through there as well.
Ideas?
Bruce
Edited by bogreen, 07 November 2012 - 10:13 PM.
#2 Tuco
Tuco
    Sōhei
  • Chief Appliantologist
  • 238 posts
  • Flavorite Brew:Tap Water
Posted 08 November 2012 - 03:56 AM
Bring a dispencer board. Unplug the old board, check for power at the plug. If the plug has a any volts, install new board.
If no power at the plug...a dispencer board is not your problem.
  • 24,333 posts
Posted 08 November 2012 - 08:13 AM
Check the wire harness connector plug at the bottom hinge of the freezer door. If it's corroded and boogared up, you'll probably need to re-spice it.
Dispenser board part link, if needed ==> http://www.repaircli...ber=PSC23SGRCSS
#4 bogreen
bogreen
    Kohai
  • 387 posts
Posted 09 November 2012 - 08:42 PM
Thank you Fermented Grand Master,
Indeed, it was the connector under the hinge. One of the wires was broken.
Thanks again,
Bruce
