how to clean mist valve on Electrolux Dryer EIMED55
mist valve electrolux
1 reply to this topic
#1 bc3
bc3
  • 17 posts
Posted 08 November 2012 - 07:30 AM
during dagnostic mode I noted no moisture coming from mist valve I believe to be located at about 11 oclock on the back wall of the dryer In test mode with flashlight and running it was dry as a bone. How to clean what may be a clog? thanks
  • 24,268 posts
Posted 08 November 2012 - 09:15 AM
Is the water supply on? Loosen the supply fitting on the valve and see if water start squirting out.
Is the valve getting voltage?
Is the valve coil open?
Does the valve open if you attach a cheater cord with 120vac to it?
If the valve is bad, then replace it ==> http://www.repaircli...e/218470300/449
