Bosch D/W SHU43CO7UC/22
Runs forever
8 replies to this topic
#1 prairiestr
prairiestr
    Sōhei
  • Chief Appliantologist
  • 189 posts
  • Flavorite Brew:Jack
Posted 08 November 2012 - 01:41 PM
I have'nt seen one of these before, customer says it will just run and run, never draining unless she selects cancel/ drain.
Suspect temp sensor or heater.
Any hints?
Edited by prairiestr, 08 November 2012 - 04:08 PM.
  • 24,296 posts
Posted 08 November 2012 - 02:44 PM
Check that model number again: is that SHU or SHV?
Also, the character after the "C" is a 0 (zero) not an "O" (the letter O)
#3 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 08 November 2012 - 02:54 PM
Thanks Samurai,
I have'nt seen the machine yet, leaving for call now. I'll get back to you.
#4 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 08 November 2012 - 04:17 PM
Model # is SHU43C07UC/22
Ran diagnostic. E1 error code (heating error)
Now for the stooopid questions;
1. Am I supposed to remove the tub from the base tray to work on this thing?
2. If so, how?
Again, this is the first Bosch I've seen.
  • 24,296 posts
Posted 08 November 2012 - 04:22 PM
This will either be an open heater or NTC (the control for the heater) or a bad control board.
A common problem is a burned solder joint on the control board but not always and this can trick people. If you're not getting the current draw that that Brother jumptrout described, then there will be one of two problems: open in the heater circuit (usually the NTC); or the control is not putting out 120vac to the heater.
It's easiest to check the control.
The control board puts out 120vac to the heater circuit on the red wire. If you're not getting the current draw through the heater, then check to see if the control is putting out 120vac on the red wire. If it is not, then the problem will either be 1) a burnt solder joint on the heater relay or 2) some other non-visible problem with the control board. I have seen the control boards fail in this manner WITHOUT the relay being visibly burnt, so you have to check for voltage the red wire to know what's going on.
The difference between the two type of control board failures is this: burnt solder joints are field repairable but the other types of non-visible failures are not.
And there there is Brother Telefunken's method for checking the heater circuit.
#6 jumptrout
jumptrout
  • 1,136 posts
  • Flavorite Brew:Coors Light
Posted 08 November 2012 - 06:05 PM
The Fermented Grand Master is correct in this diagnosis.
One additional step you can take to verify all heater components are good is; after running the dishwasher for 5 minutes to make sure water is circulating well,use a insulated jumper wire from the incoming power wire on the control board to the adjacent RED wire. Your amp meter over the red wire will read 10.5 amps if the heater components are good. This keeps you from having to remove the dw and then remove panels to access these parts unless they are bad.
#7 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 29 November 2012 - 05:37 PM
Thanks for all the help.
Replaced the control board/timer, all is working fine now!
Thanks again.
#8 jumptrout
jumptrout
  • 1,136 posts
Posted 29 November 2012 - 06:37 PM
Please tell us the steps you took to determine this repair method so that we might learn from your experience.
#9 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 29 November 2012 - 07:29 PM
jumptrout,
I followed your advice and installed jumper wire from power coming in (grey?)  to red heater wire, then used amp probe to look for current,(10amps) this told me other components were functional and the problem must in the control.
