Frigidaire FEF336ECG tripping the clock
15 replies to this topic
#1 RedToryTy
RedToryTy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 798 posts
  • Flavorite Brew:Guinness Stout
Posted 08 November 2012 - 02:12 PM
To the Dojo,
I have this freestanding range kicking my @$$. I pulled the L2 OUT off the clock, and the clock will cycle fine. With L2 OUT connected to either bake or broil, the clock resets seconds after pressing "BAKE" to initiate preheat. Household receptacle--a four-prong with L1, neutral, and L2 wired from left to right--reads 240VAC at lines 1 and 2, and 120VAC at line 1 or 2 and ground. ANY useful questions? What am I missing?
Thanks in advance,
Tyrus
Mr. Tyrus Lee Smith
Owner-Operator, Smith's Appliance Service
701 Baldwin Falls Road
Baldwin, Georgia 30511-2108
706-778-3411
#2 RegUS_PatOff
  • 30,276 posts
Posted 08 November 2012 - 02:16 PM
... 120VAC at line 1 or 2 and ground.
... receptacle--a four-prong
measured while you press Bake or Broil ?
and measure between Neutral and ground while you press Bake or Broil
#3 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 798 posts
Posted 08 November 2012 - 02:24 PM
No; measured when disconnected.
Mr. Tyrus Lee Smith
706-778-3411
#4 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 798 posts
Posted 08 November 2012 - 02:29 PM
Connected to L2 OUT and BROIL, get .354 VAC with clock and element connected.
Mr. Tyrus Lee Smith
706-778-3411
#5 prairiestr
prairiestr
    Sōhei
  • 189 posts
  • Flavorite Brew:Jack
Posted 08 November 2012 - 02:49 PM
I am sure you already considered these:
1. Bad clock
2. Bad connection at receptical/cord
  • 24,345 posts
Posted 08 November 2012 - 03:16 PM
So with L2 OUT disconnected, you get 120vac between the terminal on the ERC to ground; but with L2 OUT connected, you get essecntially 0vac? If this is correct, then it sounds like the ERC is failing under load ==> http://www.repaircli...umber=FEF336ECG
#7 RegUS_PatOff
  • 30,276 posts
Posted 08 November 2012 - 03:20 PM
all voltage measurements should be made with the devices connected, and with the problem function enabled
(unless otherwise directed)
while you press Bake or Broil, measure for
120vAC between L1 and ground
and
120vAC between L2 and ground
and
0vAC between Neutral and ground
#8 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 798 posts
Posted 08 November 2012 - 05:04 PM
This just in:
After pulling the connector cover for the cord on the back of the range, I measured 93-101VAC from L1 (Black) to Neutral and 159VAC from L2 (Red) to Neutral. Will be swapping the cord for further tests; more news as this story develops.
Mr. Tyrus Lee Smith
706-778-3411
#9 RegUS_PatOff
  • 30,276 posts
Posted 08 November 2012 - 05:13 PM
something is wrong with the Neutral / ground ..
one or the other may have a bad connection
There should be 0v between them
(connected together at the House Breaker Box)
#10 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 798 posts
Posted 12 November 2012 - 08:34 PM
Reg,
The voltages I mentioned previous were measured at the cord connection at the base of the range, not at the clock. How does this change your diagnosis?
Something hinky that stuck with me: when I checked the bake and broil elements for grounding, broil registered 30 ohms of resistance between the element and the chassis.
Will check for 120VAC between Ls 1 & 2 and neutral when I go back.
Help me, Obi Wan Kenobi; you're my only hope.
Mr. Tyrus Lee Smith
706-778-3411
#11 kdog
    RoughShod
  • 7,428 posts
Posted 12 November 2012 - 10:12 PM
Sounds like a grounded broil element done fizzled your control
Oven-Control-Board-316455400-01028898.jp
#12 RegUS_PatOff
  • 30,276 posts
Posted 13 November 2012 - 02:55 AM
bad Neutral in Power Cord, Wall Outlet, House wiring, or Breaker Box
#13 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 798 posts
Posted 13 November 2012 - 07:47 AM
Kdog,
Even with the broil element disconnected, the clock blink "12:00" as soon as it attempts to energize the "BAKE" element.
I'm just confused how the voltages can be correct at the receptacle, but measure 92-101 and 153-160 L1 and L2 respectively at the base of the oven.
Mr. Tyrus Lee Smith
706-778-3411
#14 RegUS_PatOff
  • 30,276 posts
Posted 13 November 2012 - 12:57 PM
... I'm just confused how the voltages can be correct at the receptacle,
... but measure 92-101 and 153-160 L1 and L2 respectively at the base of the oven.
measured while the Oven / Cord is still connected ?
#15 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 13 November 2012 - 02:20 PM
Something is wrong with the neutral/ground. These kind of problems make machines act CRAZY!
Those voltage readings just sound like a bad neutral.
#16 kdog
    RoughShod
  • 7,428 posts
Posted 13 November 2012 - 02:45 PM
Hook your meter up to the receptacle with the range plugged in and watch the voltage when you turn range on - does it change ?
