frigidaire dishwasher FDB989GFC2 springs
4 replies to this topic
#1 Novice134
Novice134
    Ikkō-ikki
  • 21 posts
Posted 09 November 2012 - 07:47 PM
Looking for instructions on how to replace the door springs.
I see part
Door Spring
Item # 1014399
do I need one or two.
Thank you
#2 kdog
    RoughShod
  • 7,428 posts
Posted 09 November 2012 - 08:49 PM
You should replace the pair, you need to order 2
unscrew the 2 flange brackets securing the d/w to cabinet, remove the toe kick and slide the d/w out a way - you'll see the springs/hinges on the side, pretty self explanatory when you see them. Hopefully the water line is flexible enough to allow it to slide out a bit. If it is plumbed to steel or copper line and is fixed, unscrew the valve from the frame so that it can stay put. DO NOT disconnect water line as you could be asking for trouble. If your hands are nimble enough, you might be able to install them from underneath by removing only the toekick.
#3 Novice134
Novice134
    Ikkō-ikki
  • 21 posts
Posted 11 November 2012 - 08:38 PM
thank you. will give it a try
#4 Novice134
Novice134
    Ikkō-ikki
  • 21 posts
Posted 17 November 2012 - 11:44 AM
it worked out great. thanks for your help!!
#5 kdog
    RoughShod
  • 7,428 posts
Posted 17 November 2012 - 02:27 PM
Thanks for the update ! :thumbsup:
Replacing the Door Springs in a Frigidaire Dishwasher
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 10 November 2012 - 08:47 AM
Grand Master Funk kdog calls the dance steps on this little ditty:
[quote name='kdog' date='09 November 2012 - 08:49 PM'...
Read Full Entry →
