Learn how to troubleshoot like a Master Samurai Tech...
Sign in to follow this
Followers 0
Novice134
frigidaire dishwasher FDB989GFC2 springs
5 posts in this topic
Looking for instructions on how to replace the door springs.
I see part
Door Spring
Item # 1014399
do I need one or two.
Thank you
You should replace the pair, you need to order 2
unscrew the 2 flange brackets securing the d/w to cabinet, remove the toe kick and slide the d/w out a way - you'll see the springs/hinges on the side, pretty self explanatory when you see them. Hopefully the water line is flexible enough to allow it to slide out a bit. If it is plumbed to steel or copper line and is fixed, unscrew the valve from the frame so that it can stay put. DO NOT disconnect water line as you could be asking for trouble. If your hands are nimble enough, you might be able to install them from underneath by removing only the toekick.
it worked out great. thanks for your help!!
Thanks for the update ! :thumbsup:
Followers 0
