Maytag French door Refrig MFI2568AES not making ice
How to troubleshoot
6 replies to this topic
#1 voipman
voipman
  • Chief Appliantologist
  • 11 posts
Posted 10 November 2012 - 12:42 PM
I have a Maytag French door Refrigerator with the Ice maker in the Fresh food Section. It is not making ice at this time. Freezer Temp is 0 degrees the Fresh food side is 38 degrees.
Model# MFI256AES Ser# 1196300JLC
There seems to be different componets that enable to Ice maker to make ice.
1. Ice maker
2. Ice box damper
3. Ice box fan
4. Ice box Thermistor
I can't seem to find a servce manual with wiring diagrams. I have a manual with Service diagnostics but how do I know if it's a componet or the PC board in the back. Can some one point me in the right direction on how to trouble shoot this and where I might get the wiring diagram.
#2 RegUS_PatOff
  • 30,278 posts
Posted 10 November 2012 - 02:18 PM
MFI256AES
maybe
MFI2568AES ?
also, tech sheets depending on the missing 1 or 2 missing numbers at the end of the model number ...
#3 voipman
voipman
  • 11 posts
Posted 11 November 2012 - 09:45 AM
Sorry you are right the I missed a number the Mod# is MFI2568AES but there are no numbers at the end.
thanks
#4 RegUS_PatOff
  • 30,278 posts
Posted 11 November 2012 - 10:10 AM
MFI2568AES0
Tech Sheet - 12827965.pdf
should be similar
#5 voipman
voipman
  • 11 posts
Posted 12 November 2012 - 03:50 PM
I was able to put the icemaker into a harvest mode and ejected ice that's been in there already. At the end of the cycle it filled up with water. The Ice maker has not made ice in weeks. Going into the service mode I was able to get the Ice box fan to go on and off and the damper to open and close. The Ice box thermister is indicating 20 degrees as my thermometer does. It's been my experience that an icemaker needs at least 16 degress or lower to work properly. If this icemaker was in the freezer section it would be much simple er troubleshoot. What is it that is keeping the temperature at 20 degrees?
  • 24,347 posts
Posted 12 November 2012 - 08:38 PM
What is the difference (method of measurement) between these two temperature measurements?
#7 kdog
    RoughShod
  • 7,428 posts
Posted 12 November 2012 - 09:22 PM
Added model # to topic title, you may find this download helpful.
Added the full manual to Potluck Supper - will be live soon here: http://appliantology...h-refrigerator/
This may sound stupid, but is the switch in the front of the icebin in the "on" position ?
I recall having freezing issues if it is left on without water attached to fridge, may have been disabled at some point and not turned back on.
