Asko WM90A (10505) Spring Replacement - Help!
asko wm90a 10505 spring springs
4 replies to this topic
#1 s4zando
s4zando
  • 17 posts
  • Flavorite Brew:Summit EPA
Posted 10 November 2012 - 01:10 PM
Good news: New parts arrived! Hooray!
Bad News: They're the springs for the drum - this doesn't look like as easy of a job as replacing the belt
While it would be nice ot have the actual service manual for this unit, I'm ok with going in without it, however, does anyone have any tips or potential gotchas I should be aware of?
(I have requested the service manual from here, but our chief Samurai doesn't seem to have it in the library - We have the owners manual and parts list, but no real factory service manual :(
Has anyone done this before? What's the best way to approach this task? Do I need to completely remove the drum? Do I need to get the machine on it's side or back for access to the underside? Is there a proper order of parts removal to get to replacing the springs?
Thanks!
./s4z
  • 24,296 posts
Posted 10 November 2012 - 04:51 PM
What's the part number of the springs you ordered?
#3 s4zando
s4zando
  • 17 posts
Posted 10 November 2012 - 10:44 PM
Asko Part Number: 8801036
Desc: Spring - Leg Spring
Repair Clinic Item #: 764387
#4 s4zando
s4zando
  • 17 posts
Posted 14 November 2012 - 02:11 PM
*bump* ?
  • 24,296 posts
Posted 14 November 2012 - 07:37 PM
Best thing I can find to help you with this is the diagrams/parts manual. PMed.
