Begin your journey to appliance repair mastery…
scatr
Fix venting fan for GE Microwave JVM250AV001
4 posts in this topic
Hi - I have a GE Spacemaker microwave mounted over the range, model JVM250AV001, made in May 1995. The vent fan vents to the outside of the house, or at least it used to until the fan started making a really awful noise a couple years ago. We figured there was either a physical obstruction in there, or the fan motor had gone bad. It's a bear to take off the wall, so it was a call to the repair place. They told us the fan part is no longer made. So, it's either a service call to hopefully clear an obstruction, or put it back up on the wall since nothing can be done about it. Not worth the money, so as a result, we haven't used the vent fan in about 2 years.
Recently I ran across some models much like this one in a local Habitat for Humanity ReStore shop, which I could pick up for cheap, and pilfer them for parts to repair the one in my house. My question is whether or not this is a good idea. I am reasonably handy but I need some good guidance before I try this out. One of the things I've read is that microwaves can be dangerous due to storing power even when disconnected. So, before I got into this on my own, or even possibly calling a local repair place to see if they'd be up for it, I figured I'd get some input here first. Thanks
... I could pick up for cheap, and pilfer them for parts to repair the one in my house.
WB26X167
Fan NLA at RepairClinic
some of the GE
JVM2x
JVM3x
JVM4x
JVM5x
JVM6x
series use the same Fan
OR eBay has a new one for about $ 150
looking at the photo on e bay of the motor you have , this is not the common motor that i have seen in most Ge microwaves
so be careful when buying a used micro for parts , it may not contain the motor you need
as far as ease of changeing the motor , should be no problem . but i must say , i cant think of a single one of these motor i have ever changed , these just don't go bad
the micro gives up long before there is ever a problem with a worn out motor
Any danger from shock will come from parts on the right side of the micro , just keep your hands out of there and you will be fine , even if you need to remove the cover , just keep you hands/tools clear of the parts on the right
your motor is in the center/rear of the top , it may come out with a few screws without removing anything else and then just unplugs
Guys, thanks for the info - I'll be checking this out. Since you said these rarely (never?) fail, maybe there actually is something in there that's obstructing the fan.
