Kenmore Series 90 110.C28902790 LOUD noise - transmission kaput?
#1
Posted 11 November 2012 - 08:50 AM
Thank you for any advice. I am moderately capable of do-it-myself repairs. Hope this is something fixable.
Cheers,
AuroraGuy
#2
Posted 11 November 2012 - 09:47 AM
sounds like a bad Coupler
Can you turn the Agitator either way while it's running or not running ?
- kdog likes this
#5
Posted 11 November 2012 - 01:06 PM
Checked coupling before I made the video and it looked fine. Replaced it anyway. Does not spin or agitate. Pumps water fine.
Makes a metallic "grinding" sound when trying to agitate or spin.
Other suggestions?
Thanks again.
I should add I can turn the agitator clockwise while it is trying to run. Cannot turn it counter-clockwise.
#6
Posted 11 November 2012 - 01:36 PM
during that time, does the Washer Motor help or hinder to turn the Agitator ?... I can turn the agitator clockwise while it is trying to run. Cannot turn it counter-clockwise.
#7
Posted 11 November 2012 - 01:43 PM
During wash cycle, agitator can be turned by hand effortlessly clockwise. Can't move it counter-close wise a millimetre.
#8
Posted 11 November 2012 - 04:13 PM
- kdog likes this
#9
Posted 11 November 2012 - 04:54 PM
Eric
- Samurai Appliance Repair Man, kdog and AuroraGuy like this
#10
Posted 11 November 2012 - 09:03 PM
Gear case kaput?
Really appreciate your help.
C.
#11
Posted 11 November 2012 - 09:14 PM
Run with cabinet off and get a visual, if you can verify that the transmission side of the coupler is actually turning (have been known to split during installation) then you are in for a tranny, but fear not - quite a simple job.
http://www.repaircli...er=110.28902790
(w/video):
http://www.repaircli...ion/3360629/423
#12
Posted 11 November 2012 - 09:23 PM
#13
Posted 11 November 2012 - 09:37 PM
If it needs a new transmission ($200), the question will be whether it's worth in for a 10-year-old washing machine. I'm leaning toward "yes."
#14
Posted 11 November 2012 - 10:04 PM
When you go to remove your agitator, with the 90 series, you might find that there is no bolt directly under the agitator cap. If you see a plastic piece with a square hole in it, use a 1/2" socket extension into that hole and turn CCW to release. Then you can remove the top half of the agitator to get to the bolt for the bottom half.
If you do end up opening the gearcase, set it up securely and make it level so the oil doesn't spill out when you take the cover off.
Eric
- Samurai Appliance Repair Man, jb8103, kdog and 1 other like this
#16
Posted 17 November 2012 - 11:24 AM
I have removed the gear case and opened it for inspection. Am searching this website for instructions/video on rebuilding/repairing it. Will drain the oil and clean while searching...
#17
Posted 18 November 2012 - 11:01 AM
Was thinking of overhauling the gearcase myself, but did not have the time and was uncertain I could quickly get the parts.
Cheers!
Also tagged with one or more of these keywords: Kenmore, Series 90, transmission, loud noise
