Viking VGIC3074BSS keeps sparking
viking stove spark
3 replies to this topic
#1 heappliances
heappliances
  • Chief Appliantologist
  • 4 posts
  • Flavorite Brew:coffe
Posted 11 November 2012 - 03:39 PM
Need help.
We have a Viking VGIC3074BSS which is keeps sparking on all 4 ignightors after flame is on.
We did:
1. Replaced spark module
2. Cleaned ignightors heads
3. Checked burner heads alignments
4. Checked if wires properly connected from/to spark module, ignightors, switches - correct according to diagram
5. Checked wires for any damages
After installing new spark module it was working fine for 3 - 5 min and start sparks again after.
Any help will be greatly appreciated.
Could it be problem with any switches or something else?
Thank you in advance.
#2 RegUS_PatOff
  • 30,221 posts
Posted 11 November 2012 - 04:16 PM
Has this Cooktop worked OK up till now at this location ?
Has there been any recent House electrical wiring done ?
Have you check the Wall Outlet polarity L1, L2, and ground ?
  • 24,258 posts
Posted 11 November 2012 - 04:35 PM
Did you remove and clean the burner heads with emery cloth?
As Reg mentioned, outlet polarity is critical in these units.
#4 kdog
    RoughShod
  • 7,428 posts
Posted 11 November 2012 - 08:44 PM
http://www.amazon.co...G/dp/B002Q3R7HI
