Bosch Dishwasher SHE6AF06UC/05 leaks and won't complete cycle
Bosch Dishwasher Leak
8 replies to this topic
#1 jfpdazey
jfpdazey
  • 4 posts
Posted 11 November 2012 - 10:21 PM
Our Bosch dishwasher (Model SHE6AF06UC/05) recently suffered the disgrace of having our 6yo son fall onto the door while open. While he quickly recovered, I am afraid our poor dishwasher has not.
The d/w will turn on, but will not start a cycle (timer simply flashes) unless pressure is applied to the door or an object is wedged under or around the door to apply pressure. Even yet, it will not run through a complete cycle without constantly bumping and adjusting the pressure on the door. At various random points in the cycle, it goes back to flashing and needs to be re-adjusted. We've also noticed that the timer doesn't seem to always be moving forward - we've once or twice caught it flashing with a higher time remaining than before. Oh, and we've now seen some leaking/bubbling out of both the top and bottom corners - a few ounces during what we can get out of a cycle.
Between my father-in-law and I, we've had the dishwasher out a couple of times - inspected springs, done some careful hammering on the hinges to even them on both sides (so they stop at the same point), carefully flexed the inner door panel door slightly upward to try to achieve a better seal on the top, cleaned the mineral deposits off the inner door and the inner rubber gasket. So far - it's no go.
Any thoughts or advice? Just picked this d/w up a couple years ago - and I'd really hate to kiss it goodbye so quickly.
JFPD
#2 certified tech group 51
  • 1,972 posts
Posted 11 November 2012 - 11:29 PM
Do not know your exact model , but , there is /are switches in the door handle...........Some open/close the hot side, some open/close the neutral side and some open/close both...............With out the correct closing of the switches and staying closed, the machine will be stopping and starting with the pushing/ twisting of the door to keep the switches in the closed position.........It may start but when the inner door panel expands from the heating of the panel, the switch(es) appear to be opening the circuit..........Water leaking is, water leaking from not sealing correctly.........Price a set of door hinges, gasket, inner door panel, door frame, check the door latch for broken parts, straighten the frame VS. replacement...............
#3 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 12 November 2012 - 12:30 AM
There is a service bulletin on this issue. These dishwashers use a magnetic door latch with no microswitches in it. if the magnets don't line up perfectly, the door will unlatch itself. What causes this issue is a poor installation under the counter. Make sure the dishwasher sits level under the counter and the door isn't rubbing the kitchen cabinets or the underside of the countertop. You will need to relevel the dishwasher and make sure it sits squarely in the hole.
Scott Wolf
#4 telefunkenu47
telefunkenu47
    Kohai
  • 322 posts
Posted 12 November 2012 - 07:38 PM
also, you may need new hinges. once they are sprung, its almost impossible to get the door alignment right.
Even root canal is easy...if you're a dentist...
  • 24,217 posts
Posted 12 November 2012 - 08:30 PM
Right door hinge ==> http://www.repaircli...r=SHE6AF06UC/05
Left door hinge ==> http://www.repaircli...r=SHE6AF06UC/05
Door latch assembly ==> http://www.repaircli...r=SHE6AF06UC/05
#6 jfpdazey
jfpdazey
  • 4 posts
Posted 12 November 2012 - 10:18 PM
Thanks to all for your quick replies! Going to start by releveling tomorrow night as I do think that's off - though the dishwasher is properly centered and not touching the cabinet. I've pulled it out and reinstalled it myself twice this past week while checking hinges, so I'm fairly sure of that at least.
I'll touch base again after spending a little more quality time with the d/w... :-)
JFPD
#7 jfpdazey
jfpdazey
  • 4 posts
Posted 19 November 2012 - 10:40 PM
Well, after a long week, finally got to the dishwasher earlier today. Was definitely out of level - but unfortunately, levelling it did not solve the issue. Still stopping several times a cycle and having timer issues.
The hinges are on order, and I will be attempting to replace them Wednesday night - hoping for the best!
JFPD
#8 jfpdazey
jfpdazey
  • 4 posts
Posted 10 December 2012 - 10:29 PM
Thanksgiving prep and two weeks of vacation killed any plans for appliance repair I may have had in November, but I was able to get around to replacing the hinges this past weekend, and...
IT WORKS!!!
After removing them and comparing to the new hinges, it was easy to tell that the old hinges were noticeably sprung.  We've been able to run four complete cycles with no leaks, starting/stopping, or strange timer issues.  My best guess is that the earlier timer issues had something to do with the "smart cycle management" system having conflicts with the repeated starting/stopping and leaking.
I've consulted the forums several times for help with other minor appliance repairs (and found the knowledge invaluable), but this is the first time I've actually logged on and asked the enlightened ones for assistance.  All I can say is, WOW - what a great group of people you have here on the forum!  Many, MANY thanks to all of you who responded and provided guidance!
  • 24,217 posts
Posted 10 December 2012 - 10:31 PM
Nice job, jfp!  Congrats on the repair and domo for the followup.   :rocker:
Also tagged with one or more of these keywords: Bosch, Dishwasher, Leak
