JGP636WEV7WW GE Gas Cooktop All three burners clicking when turning on one burner
5 replies to this topic
#1 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 295 posts
  • Flavorite Brew:Coors Light or Vodka
Posted 12 November 2012 - 09:41 AM
JGP636WEV7WW what might cause several burners to click and continue to click when unit is off? the only way to stop the clickicg is to unplug
Spark Module?
Update: now none of the burners click or ignite.
Edited by richseattle56, 12 November 2012 - 12:01 PM.
  • 24,258 posts
Posted 12 November 2012 - 03:19 PM
Clicking with all burner switches off is usually an indication that one or more of the burner switches got wet. If this is the case, and given the evolution of the problem, it's possible that the spark module has now been damaged or the spill has spread and is now grounding out the spark in the spark wires before it reaches the electrodes. Open it up and check for evidence of spills or residual wetness. Check for valid L1 supply with proper polarity to the spark module. If that checks good, and the spark module will not produce spark when one of the burner switches are closed, then replace the spark module. ==> http://www.repaircli...er=JGP636WEV7WW
#3 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 12 November 2012 - 06:04 PM
Could I try drying everthing out, befroe replacing any parts. And it there a way to check the spark module, the cooktpo has worked finr for years and nothing has changed so the polarity should be OK.
  • 24,258 posts
Posted 12 November 2012 - 06:46 PM
I've had mixed success with removing the knobs and using a hair dryer.
Only what I already explained in my previous post.
#5 kdog
    RoughShod
  • 7,428 posts
Posted 12 November 2012 - 10:26 PM
Never assume that, check with meter to verify - also if you disconnect the offending switch, the sparking should stop if it's a bad switch.
Spark-Ignition-Switch-WB24K5083-00804676
Spark-Ignition-Switch-WB24K5078-00804232
#6 richseattle56
richseattle56
    Kohai
  • 295 posts
Posted 14 November 2012 - 09:04 PM
Was the spark module. Replaced and all is well. Ready for the holiday.
Thanks to all.
