f7/e7 fault code ge range need tech sheet JSP47CF5CC
tommytech
And that model number is... ?
It is there you just can't see it on your Iphone
Added to topic title
Sounds like a touchpad issue (loose connection)
Click on Pic:
Domo, kdog. You are right-- I am posting via my iPhone (and usually do) but I still can't see the model number in the topic title. Whazzup widat, yo?
I think it was you who told me that when threads are posted via mobile, the model number shows up small and light colored under the topic - no smartphone here .......... yet
Ah, I see it now-- it shows up in the topic listing view but not when you're actually reading the topic, when you need it the most. Domo!
