GE Dishwasher Model #GSD2635FOOWW
#1
Posted 13 November 2012 - 10:03 PM
No power to the water inlet valve
No power to the float switch
No power to the drain solenoid anywhere on the timer.
I changed the timer.
Everything remained the same. No water.
Bruce
#2
Posted 14 November 2012 - 01:37 AM
#3
Posted 14 November 2012 - 02:15 AM
Check the timer motor continuity. Also see if you're getting 120vac to the timer motor during the cycle.
- kdog likes this
#4
Posted 14 November 2012 - 10:00 AM
Unit is acting exactly the same as with the original timer.
No power to the water valve or the drain solenoid.
No power to the float switch or from the switch.
What are the chances that a new timer would perform exactly the same as the old one.
I smells something else wrong that's stopping the power to the water valve.
Any other ideas?
Bruce
#5
Posted 14 November 2012 - 07:03 PM
- kdog and Chat_in_FL like this
#6
Posted 14 November 2012 - 07:04 PM
Edited by Chat_in_RI, 14 November 2012 - 07:05 PM.
Mother Teresa
#7
Posted 14 November 2012 - 09:18 PM
I went back today to look again.
I ohmed the pink wire from the timer connector to the float switch and it had continuity.
I took the two wire connector off the motor and put it on the water inlet valve and there came water, and the
drain solenoid had power and drained the machine.
Then I hooked my meter to the timer connector pink wire which supplies the water valve and to ground and there
was no power coming off the timer anywhere on the dial. (I turned it all the way around).
I told the customer, if I hadn't been here before, ha ha, I'd say you need a new timer.
It sure is looking like my new timer is bad.
Bruce
- kdog likes this
#8
Posted 14 November 2012 - 09:52 PM
Exceedingly rare with these simple timers but seems to be a posseepooplay, as they say in Quebecwa-muddafukka.
- kdog likes this
#9
Posted 14 November 2012 - 10:10 PM
Sacre' Bleau !
#10
Posted 15 November 2012 - 11:44 PM
#11
Posted 29 November 2012 - 10:37 AM
Ok, I changed the timer again. Still the same. No power to the inlet valve.
I jiggled the wires in the door and here comes the water.
So, now I have a bad wire somewhere on the harness.
The unit worked a couple of times for the customer, but yesterday she called and it is doing
the same again.
Anybody have the wiring diagram for this machine??
And how would you go about isolating "THE" bad wire??
Bruce
#12
Posted 29 November 2012 - 09:23 PM
Must be the feed wire to the float switch/valve that's the issue - inspect it carefully and splice in a replacement if necessary - assuming water fill is all that is effected
#13
Posted 30 November 2012 - 11:15 AM
I would agree, so I checked voltage at the timer connector. The wire feeding the water valve had no voltage coming off the timer.
That's why I suspected the timer as the problem.
It seems to be a wire that feeds the timer and then throws power over to the water fill valve.
Does that make sense?
A schematic would definitely help.
#14
Posted 30 November 2012 - 08:24 PM
This One should be close enough, nothing else there, just the valve, gloat switch and 2 timer contacts
