Spin problem
11 replies to this topic
#1 Pappy
Pappy
  • 5 posts
Posted 14 November 2012 - 10:34 AM
I have an Affinity ATF6000ES1 washer. It appears to go through all cycles ok until the spin cycle. It will start to spin somewhat but it is erratic and not smooth and after a few seconds it will quit. I tried spinning it by hand and their appears to be resistance. Any help would be appreciated!
#2 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
  • Flavorite Brew:yeunling
Posted 14 November 2012 - 06:40 PM
the basket should spin freely, check for items stuck between the basket and the outer tub, i see this often on these models
#3 Pappy
Pappy
  • 5 posts
Posted 15 November 2012 - 11:48 AM
How do I check for this? Through the front or through the back? Thanks for your help!
  • 24,713 posts
Posted 15 November 2012 - 11:51 AM
Open the door and spin the inner basket by hand. And check the bearings while you're in there...
#5 Pappy
Pappy
  • 5 posts
Posted 15 November 2012 - 01:00 PM
The bearings seem ok. Everything was tight. I again tried to turn the tub and it mostly turns easily until it meets some resistance. I took the belt off and it still does the same. The is nothing visible from the front in between the basket and the tub. Thanks.
#6 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
Posted 15 November 2012 - 04:09 PM
sounds like there is somthing in there, try taking off the hose from the dispesnsor to get a look in there, also shine a light in the tub and see if u see anything
#7 kdog
    RoughShod
  • 7,433 posts
Posted 15 November 2012 - 06:40 PM
Sounds like a sock or undies are rolling up on ya when turning the drum around - some of these baskets have access holes between the tubs hidden under the drum fins - fin has a screw that comes out and you slide the fin sharply towards the front. Can also remove the tub to pump grommet and fish through there - probably administer a CrapTrap Enema at the same time.
  • 24,713 posts
Posted 15 November 2012 - 06:42 PM
... probably administer a CrapTrap Enema at the same time.
Let us attend Ye Olde Crap Trap Enema...
#9 Pappy
Pappy
  • 5 posts
Posted 15 November 2012 - 11:26 PM
Ok, there is definitely something in there. I can see it through the holes under the drum fin. Unfortunately there is no way to get it out through here. How can I access this area? Thanks for all of your help!
#10 kdog
    RoughShod
  • 7,433 posts
Posted 15 November 2012 - 11:42 PM
#11 Pappy
Pappy
  • 5 posts
Posted 16 November 2012 - 12:07 PM
A pair of my grandson's pajama bottoms! I was able to find it and pull pieces at a time through the little holes and then cut off with a knife. Once I got control of it the I moved it to the bottom and took it out through the drain. It spins freely now! Thanks again!
#12 Samurai Appliance Repair Man
  • 24,713 posts
Posted 16 November 2012 - 03:13 PM
Nice work! Did you fish them out from the tub-to-pump port?
