The freezer is doing good. The FF section is room temp.
Right away I'm thinking damper, but I have not yet begun to test. A tech sheet to tell how get into diagnostics mode would be super duper.
Edited by jb8103, 14 November 2012 - 10:56 PM.
Posted 14 November 2012 - 10:55 PM
Posted 14 November 2012 - 11:44 PM
http://www.mediafire...9tco5sb28pc7w1n
This is a pretty typical unit so this techsheet should work for you
When looking behind kickplate you may not see the sheet caus it is stuck up to the underside in a plastic jacket, you gotta get your eyeballs right down on the floor to see it, cut the pouch and remove (don't forget to put it back)
Damper failures are pretty common on these
http://www.repaircli...er=596.65939401
They have a kit out that is an upgraded design, comes with new styrofoam cover/harness etc. - though R/C is calling it a "thermostat" the kit is here
Posted 15 November 2012 - 11:40 PM
Posted 16 November 2012 - 05:10 PM
Posted 19 November 2012 - 10:00 PM
