Whirlpool Cabrio Washer: WTW6600SW2
10 replies to this topic
#1 GreenestOne
GreenestOne
    Yamabushi
  • Chief Appliantologist
  • 70 posts
  • Flavorite Brew:java
Posted 14 November 2012 - 11:16 PM
Customer complained of high speed spin sounding like an airplane taking off in their house.
Machine would also stop before drain cycle would start. There was an F51 error code.
I entered the diagnostic mode and ran both automatic and manual tests and everything seemed to be working.
i read on a forum that the RPS connection may have a coating on it from the factory which has been known
to eventually produce a faulty connection at the harness. I removed the harness and scraped the terminals
and carefully cleaned them with a solvent. I reassembled the parts and plugged the washer back in.
When starting a new cycle on "normal" the sequencing of agitation and incoming water seemed to be out of sync.
Only a small amount of water would come in then agitation would start, small amount of water, then agitation, etc.
I checked the pressure sensing tube which appeared to be clear and no kinks or cuts. I deduced that a new control board
was needed. I had one for this model, replaced it and the washer seemed to be working normally. I put it through a short
cycle, water inlet flow was now normal, agitation, spinning, draining, etc.
The next day the owner called me saying that the machine was spinning "dangerously fast" and very loud.
I didn't ask her if the F51 code was showing up again. Again, when I ran the diagnostic for the RPS, the LED display
showed that it was working correctly. I have read about many compliants about this model with people saying that they
had replaced both the motor control and the RPS and were still having problems.
What is the next step?
#2 Skiter29
Skiter29
    Kohai
  • 315 posts
Posted 14 November 2012 - 11:48 PM
the load noise might be the tub bearing has gone out so it has been leaking it might be spinning normal but with the bearing being load it might sound thats its spining out of control check underneath and see if it looks like its been leaking
#3 GreenestOne
GreenestOne
    Yamabushi
  • 70 posts
Posted 15 November 2012 - 11:54 AM
There were no leaks at all. Even when I pulled the circular magnet ring off the bottom to check the connections on the RPS there was no moisture.
  • 24,207 posts
Posted 15 November 2012 - 12:44 PM
Look at the very bottom center of the rotor at the allen head bolt. It has a tendency to back out causing weird noises and throwing F51 error code. Add a dab of locktite and cinch it down goodntight with that nifty disposal unjamming wrench that you were wondering what to do with.
#5 nickfixit
nickfixit
  • 1,962 posts
Posted 15 November 2012 - 09:32 PM
I pitch in with my normal cabrio advice. Pull the basket and inspect the main shaft. If it is rusted or covered with gookus. If so, the basket will not rise and fall properly with the wash and spinning. If it does not drop fully down in spin, it will be real loud with excessive vibration, and give F51 codes.. Clean the shaft and the inside of the basket bearing, put a thin coat of grease on them, and put it back together. Test it out and see if it works properly.
And, Obama sucks.
Edited by nickfixit, 15 November 2012 - 09:33 PM.
#6 john63
john63
  • 1,411 posts
Posted 15 November 2012 - 09:47 PM
<<<And, Obama sucks.>>>
I second that :)
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#7 GreenestOne
GreenestOne
    Yamabushi
  • 70 posts
Posted 16 November 2012 - 11:26 AM
I could not even pull the tub completely off due to rust. I sprayed some break free solvent waited , no go. ( I actually pulled the whole machine off the floor trying
to release the inner basket.) I told the owner the shaft and inner bearing which comes pressed into the tub would have to be replaced. They are opting for a new machine.
BTW, the allen head bolt was tight when I checked it. I could have laid the machine on it's side and used a 2x4 and hammer on the shaft, but in this case i decided not to.
  • 24,207 posts
Posted 16 November 2012 - 03:17 PM
You should also tell them that they caused this problem by not using HE detergent in this machine. It's failure prone anyway but especially if it's run with non-HE detergent. The same fate most likely awaits the whatever replacement they get.
#9 mark mac
mark mac
    Sōhei
  • 190 posts
Posted 16 November 2012 - 04:24 PM
and obama still sucks
#10 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 17 November 2012 - 01:31 AM
ALL politicians suck, they all are liars, enough said.
Scott Wolf
  • 24,207 posts
Posted 17 November 2012 - 09:00 AM
