Kenmore 790.9611940C stove
2 replies to this topic
#1 ltramon45
ltramon45
    Yamabushi
  • 61 posts
Posted 15 November 2012 - 12:06 AM
Trying to fix my brothers stove. He has a Kenmore 790.9611940C stove and the ovens lower heting element is not heating. When he tuns the oven on the element does not heat. I need a trouble shooting manual/ Can anyone help?
#2 kdog
    RoughShod
  • 7,433 posts
Posted 15 November 2012 - 12:32 AM
Check for 240 vac at bake element terminals when unit is on, if you have the correct voltage, replace the element
http://www.repaircli...ber=7909611940C
If you do not see the voltage there, replace the control
Oven-Control-Board-316557118-01095990.jp
#3 certified tech group 51
  • 2,045 posts
Posted 15 November 2012 - 01:21 AM
Also, If only 120 VAC, check the breaker or the terminal strip where the power cord is attached.......Could be one dead leg.............
