JVM1631WJ01 Microwave
microwave door
2 replies to this topic
#1 vee8power
vee8power
    Sōhei
  • 118 posts
  • Flavorite Brew:Folgers
Posted 17 November 2012 - 09:27 AM
I want to replace the outer door
http://www.repaircli...5X10828/1263517
As I was prying the inner ring off, it started bending so I stopped. Has anybody had success getting one of these doors apart without breaking anything?
  • 24,345 posts
Posted 17 November 2012 - 03:32 PM
Remove the door from the unit and remove the handle. You will need a stiff blade putty knife or screwdriver, to insert between the inner metal door panel, and the outer plastic frame. You will need to pry up and out on the plastic frame tabs, until they are dislodged from the metal frame, you'll need to do this all the way around the door.
#3 vee8power
vee8power
    Sōhei
  • 118 posts
Posted 21 November 2012 - 08:36 AM
Thanks Samurai, The repair went without a hitch... or a crack :thanks:
Also tagged with one or more of these keywords: microwave, door
