Loctite Freeze and Release
New product
9 replies to this topic
#1 nickfixit
nickfixit
  • 1,988 posts
  • Flavorite Brew:Glen Livit
Posted 18 November 2012 - 09:04 AM
Anyone try any of these new "thermal shock/penetrant" products? It looks like something worth trying.
#2 kdog
    RoughShod
  • 7,433 posts
Posted 18 November 2012 - 10:12 PM
#3 Patricio
Patricio
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 501 posts
  • Flavorite Brew:Most anything wet excluding DR. Pepper
Posted 18 November 2012 - 11:46 PM
Can't get either one of the videos to play.
IgonFishn & Tight Lines
  • 24,692 posts
Posted 19 November 2012 - 08:52 AM
Why does LG use two different types of Loctite? What's the functional difference between the Blue (242) and the Red (271) Loctites?
#5 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
  • Flavorite Brew:yeunling
Posted 19 November 2012 - 08:11 PM
i believe red is much stronger
#6 KurbyMstr
KurbyMstr
    Yamabushi
  • 66 posts
  • Flavorite Brew:Cherry Coke
Posted 20 November 2012 - 11:26 AM
Like sh2sh2 said, red is stronger. You only use red when you have no intention of trying to break it loose later. Blue holds well, but is easier to break loose when you need to.
#7 kdog
    RoughShod
  • 7,433 posts
Posted 20 November 2012 - 07:09 PM
You often require heat etc when removing a bolt locked w/red, whereas a good jar with an adequate wrench/socket you can remove blue.
I normally carry with me threadlocker 292, wicking grade (usually light green or purple) - designed to run into threads without loosening and holds most of what I deal with around appliances. Pretty expensive stuff generally, around cars you sometimes need the high strength stuff.
#8 john63
john63
  • 1,411 posts
Posted 20 November 2012 - 09:57 PM
<<<I normally carry with me threadlocker 292, wicking grade (usually light green or purple)>>>
Same stuff I use :)
Just had an LG WM0642 washer tonight with a stripped ROTOR (no threadlocker visible on factory-installed 17mm bolt).
New ROTOR installed---and threadlocker (green color)---good as new.
FWIW---New ROTORS have been re-designed from having a plastic spline---to a steel spline (a bit overdue).
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
  • 24,692 posts
Posted 24 November 2012 - 09:42 AM
The Threadlocker 242 that I've found is all blue:
Whereas the Threadlocker 290 is green:
Is there a green 242 or are you guys referring to the 290?
#10 Patricio
Patricio
    Senpai
  • PipPipPipPip
  • 501 posts
Posted 24 November 2012 - 09:49 AM
Back in the day when I rebuilt muscle car motors I used to get locktight red or blue at the auto supply houses. They still carry it only it has gotten expensive. Good Stuff. :thumbsup:
