SAMSUNG FRIDGE WALL DIVIDER GETTING HOT
4 replies to this topic
#1 dryerman45
dryerman45
    Yamabushi
  • Chief Appliantologist
  • 65 posts
  • Flavorite Brew:rootbeer
Posted 18 November 2012 - 11:41 AM
Hi ,
I have a Samsung fridge model # RS2630SH, and the wall divider is getting hot.Going on the call tommorow.I think that the condenser fan is probually not working.Any tips on this would be appreciated.
Dryerman45 aka AL
#2 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 18 November 2012 - 11:54 AM
It is designed to keep moisture from forming between compartment.
Takes the place of the old condensate heaters.
Could reach about 110 degrees.
Normal operation.
#3 BryanS
BryanS
    Yamabushi
  • 88 posts
Posted 18 November 2012 - 12:26 PM
I have changed of few of those condensor fan motors on these. Get the fan blade as well, they break easy, and on there pretty tight. The fan motor may be extremely hot. The rubber front and back mounts on the motor become brittle as well. You can still use them most of the time. I used channel locks to turn them off instead of prying on them.
  • 24,721 posts
Posted 19 November 2012 - 08:54 AM
Condenser motor assembly ==> http://www.repaircli...701949A/1488635
Condenser fan blade ==> http://www.repaircli...100010D/2030072
#5 dryerman45
dryerman45
    Yamabushi
  • 65 posts
Posted 19 November 2012 - 07:36 PM
Thank you Master and guys,
The condenser fan motor was totally seized up.Replacing tommorow.
