Whirlpool ler5636jq0 doesn't work on Automatic setting; dries fine on timed
#1
Posted 19 November 2012 - 09:30 AM
This dryer works perfectly fine on the timed setting, but doesn't heat at all when we use automatic. I hoped maybe a sensor would be bad, but I don't see one inside the drum. Any ideas?
Jim
#2
Posted 19 November 2012 - 10:59 AM
the only difference is the advancement (or pausing) of the Timer Motor
#3
Posted 19 November 2012 - 02:22 PM
Without a (visible) sensor, what does it use to determine when the clothes are dry? Whatever it is appears to think the clothes are already dry.
#4
Posted 19 November 2012 - 05:39 PM
Doesn't make sense ...OK...so why would it be that on the auto dry setting it doesn't get hot at all?
It may be bad Contacts in the Timer
During the Auto-dry cycle, when the Thermostat "opens" the Timer is then allowed to advance ...
There wouldn't be any heat, in any cycle, if the Thermostat stayed "open"
Also tagged with one or more of these keywords: sensor, automatic, auto
Appliantology Appliance Repair Forums →
The Kitchen Appliance Repair Forum →
Maytag Model MZD2768GEW automatic temerature controlled crisper drawer problemsStarted by wrangler, 25 Nov 2011 |
The Laundry Appliance Repair Forum →
Sensor for Whirlpool dryer GGW9878PW0Started by Fire Chief, 02 Nov 2011 |
Jenn Air Downdraft Slide-in JDS9865bdpStarted by jedhaft@live.com, 04 Oct 2011 |
