Maytag MED5700TQ0 Electric dryer
no start motor will not run
12 replies to this topic
#1 rolandvz71
rolandvz71
    Sōhei
  • Chief Appliantologist
  • 194 posts
  • Flavorite Brew:Sweet Sun Tea w/lemon
Posted 19 November 2012 - 07:42 PM
Ok I know it sounds like a simple fix but this thing is eating my lunch!
Motor will not start....I have checked and the following and all have ohmed out good....
1. Non rest OL for the motor (thermal cutoff)
2. Operating thermostat
3. Hi limit Themro
4. Heater
5. Door switch
6. Ohmed motor windings (I even hard wired to start so I know it runs)
7. Timer motor runs I can see it rotating
8. Will not start in any cycle
Edited by rolandvz71, 19 November 2012 - 07:42 PM.
#2 sh2sh2
sh2sh2
    Sōhei
  • 211 posts
  • Flavorite Brew:yeunling
Posted 19 November 2012 - 08:06 PM
thermal fuse? (or is that what you are refering to as motor cut off), little white thing
#3 RegUS_PatOff
  • 30,201 posts
Posted 19 November 2012 - 09:05 PM
... Motor will not start....
Does it try to start ?
Does it make any noise ?
#4 rolandvz71
rolandvz71
    Sōhei
  • 194 posts
Posted 19 November 2012 - 11:04 PM
Yes "little white thing"
No start at all.....dead--no movement
No noise, when I the press start button while holding door switch I do hear the start engage
Edited by rolandvz71, 19 November 2012 - 11:49 PM.
#5 rolandvz71
rolandvz71
    Sōhei
  • 194 posts
Posted 19 November 2012 - 11:23 PM
For some reason I keep coming back to the selector switch......I think I am ohming it out right......when I do ---I am not getting the readings like the drawing has stated.
#6 kdog
    RoughShod
  • 7,428 posts
Posted 20 November 2012 - 12:21 AM
thermal fuse?
This one located in the back on the blower housing ? (2 blue wires)
http://www.repaircli...mber=MED5700TQ0
#7 rolandvz71
rolandvz71
    Sōhei
  • 194 posts
Posted 20 November 2012 - 12:36 AM
Yes I checked that and it good....even bypassed it to see if my meter was not reading correctly ----that did not work and NO-GO
#8 kdog
    RoughShod
  • 7,428 posts
Posted 20 November 2012 - 12:59 AM
See if BK-BU closes on timer, also push to start switch - Or/Wh to BU should close when button pressed
T-W on timer must close as well.
Seems to me that T-W contact has fooled me before
#9 rolandvz71
rolandvz71
    Sōhei
  • 194 posts
Posted 20 November 2012 - 11:36 AM
Kdog this is what I came up with....
All checked out good EXCEPT T-W contact not closing on demand
You are da man!!!
Thx for all the help!
#10 rolandvz71
rolandvz71
    Sōhei
  • 194 posts
Posted 23 November 2012 - 01:00 PM
OK gotta a question......why is the "T-W contact" there? What is its purpose?
When I bypassed it to eliminate the timer it seems to work in all cycles.......just would like to know why would they install a redundant switch inline w/the motor?
Edited by rolandvz71, 23 November 2012 - 01:00 PM.
#11 kdog
    RoughShod
  • 7,428 posts
Posted 24 November 2012 - 12:06 AM
So they would have a market for all those cases of timers stored in the spare parts area.
Likely for added safety thereby breaking both sides of the line when in the off position.
#12 rolandvz71
rolandvz71
    Sōhei
  • 194 posts
Posted 24 November 2012 - 07:14 PM
Ok, sounds about right, but when the timer times out the motor stops and when I opened the door the motor stopped..........So I am going with
sell more timers in the spare parts bin.
#13 kdog
    RoughShod
  • 7,428 posts
Posted 24 November 2012 - 09:41 PM
When the timer cam has advanced to the off increment, both the neutral and the hot are disconnected at the timer - if only 1 side is, components can then remain live when a short/ground etc occurs
