LG Washing Machine won't turn on unless I unplug and replug in to 'reset'
11 replies to this topic
#1 tchristensen
tchristensen
  • 4 posts
Posted 19 November 2012 - 08:48 PM
I have a 2 year old LG washing machine, WM2801HRA. It is not starting up when pushing the power button (as if it has no power) but the interior light is illuminated. I can get it to work if I unplug the machine wait a few seconds and plug it back in. It will start as normal. However, after every load of laundry the washer will be 'dead' (as if no power) again. If I unplug the machine, it will start back up and I am able to do one load. Also, the interior light stays on and will not go off when the machine is 'dead'.
I have read a little online and some have suggested it is the circuit board or the noise filter. Do you have any suggestions? Thanks for your time.
I buy all my appliance parts right here with a one-year return policy!
#2 john63
john63
  • 1,411 posts
Posted 19 November 2012 - 09:16 PM
<<<It is not starting up when pushing the power button (as if it has no power) but the interior light is illuminated.>>>
Are the CONTROL PANEL lights on as well?
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 tchristensen
tchristensen
  • 4 posts
Posted 19 November 2012 - 09:57 PM
No, only the interior illumination light is on. Nothing lights up or powers up when I push the power button. However, after I unplug and plug back in the control panel lights come back on and I can use the control panel to select my wash cycle.
Thanks for your help!
#4 john63
john63
  • 1,411 posts
Posted 19 November 2012 - 10:10 PM
Try the following---when the washer will not "wake-up"...
1) Press the START button at each corner (north/south/east/west). If the washer CONTROL PANEL "wakes-up" reliably at any position---check the START button. Does it look crooked/out-of-position compared to the POWER button?
If so---replace the CONTROL PANEL COVER.
2) If the START button looks normal---replace the DISPLAY BOARD.
3) Tap/bang on the washer at the top/left/rear corner (without damaging the sheetmetal or paint finish).
If the CONTROL PANEL "wakes-up"---replace the MAIN BOARD (sticking Power Relay).
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#5 tchristensen
tchristensen
  • 4 posts
Posted 19 November 2012 - 10:22 PM
Thanks! I have a load of laundry in now, I will try this tomorrow morning and report back.
#6 sh2sh2
sh2sh2
    Sōhei
  • 211 posts
  • Flavorite Brew:yeunling
Posted 20 November 2012 - 07:28 PM
i find this problem is often times the main board, on both lg and kenmore/lg's
#7 kdog
    RoughShod
  • 7,428 posts
Posted 20 November 2012 - 07:54 PM
#8 tchristensen
tchristensen
  • 4 posts
Posted 20 November 2012 - 10:35 PM
Update: I always run the washer on the 'speed wash', because I don't like waiting over an hour for a load of laundry. Last night I tried the perm press and the washer did not 'shut down' after the cycle. Tonight when I got home, the washer was still working. We are getting ready to go on vacation and are doing quite a bit of laundry, all on normal and perm press and the washer seems to be working fine this evening. I will try running another 'speed wash' when I get back from vacation, to see what happens. So far it appears that the washer only 'shuts down' after 'speed washing'.
Thanks for all your help. When I get back next week, I will run a few trials with the washer and if it 'shuts down' again I will try the suggestions above and report back.
#9 john63
john63
  • 1,411 posts
Posted 20 November 2012 - 10:58 PM
<<< I always run the washer on the 'speed wash', because I don't like waiting over an hour for a load of laundry.>>>
I've lost count---how many times that a customer has described that symptom to me.
If an LG washer takes "more an an hour of run time" during a NORMAL WASH cycle---this is usually caused by too much laundry detergent (or the incorrect type).
If more than the following amount of detergent is used...
HE (regular strength) : (2) Tablespoons Per Wash Load
HE 2X (double concentrated): (1) Tablespoon
HE 3X: (triple concentrated): (1) Teaspoon
...during the RINSE portion of the cycle (about 36 minutes remaining)---the MAIN BOARD will detect the presence of suds.
At which point the COUNTDOWN DISPLAY CLOCK will ***stall*** at "36 minutes".
The MAIN BOARD then activates a hidden software program called:"SUDS KILL MODE".
Suds Kill is a software program that will attempt to reduce the amount of suds in the washer (usually cannot achieve success).
Whenever Suds Kill becomes "enabled"-----a 51 minute NORMAL cycle will end up taking about 120 minutes to complete the cycle.
<<<When I get back next week, I will run a few trials with the washer and if it 'shuts down' again I will try the suggestions above and report back.>>>
Sounds good :)
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
  • 24,243 posts
Posted 21 November 2012 - 10:49 AM
That video was INSANE, kdog! Watched it with my sons and we were cracking up. Good find!
#11 kdog
    RoughShod
  • 7,428 posts
Posted 21 November 2012 - 04:33 PM
Heh Heh Heh ............... ;)
The squeak toy was made in Korea
#12 RegUS_PatOff
  • 30,216 posts
Posted 21 November 2012 - 04:44 PM
someone has too much time on their hands ...
I gotta watch that again... :whistling:
