Viking D/W # VDB 450 SS
1 reply to this topic
#1 certified tech group 51
  • 1,993 posts
Posted 20 November 2012 - 10:43 AM
Customers complaint "Will not start" The display is flashing/blinking for ( 3 left buttons ) Pots/Pans--Normal wash---Econo wash.......Push and hold cancel button for four seconds and the 3 lights stop flashing and last cycle selected button/light will flash...................Push the start button, close the door but with-in 4 seconds the three left buttons/ lights start to flash.....You can hear relays click from the control board , located lower left, shoved under the unit ............The use and care guide states to 'Push the start button and close the door with-in four seconds'............I accessed the door switch and the door switch was depressed ( on position ??)............... No wire diagram/schematic found on the machine.....................The lady stated that it has been doing this for a while, possibly for the past year, getting more frequent...She just pressed 'cancel' and then 'start' and it would work...........I was leaning towards the door switch.............Combing the fix-it sites I found the exact complaint and the FixYa site, the guy stated a 'drain problem'........I hate to have to pull a unit and chase wires, but............................Another statement listed this Viking as an Asco model # DBF450, but I ain't seen one of them either..................................P.S. found the fault code for the three flashing buttons, it states " Flood Sensor Disconnect " is at fault............Rats, I did not see any water in the bottom, much less a " Flood Sensor Disconnect"..... Now I gotta find a loose connection... .
Edited by certified tech group 51, 20 November 2012 - 11:58 AM.
#2 certified tech group 51
  • 1,993 posts
Posted 08 December 2012 - 12:19 PM
Unit fixed............Gotta service manual from Viking .........Replaced the Moisture Sensor and the wire harness........Story in the Dojo, complete with pictures ......................
