estate dryer no power EED4400WQ0
26 replies to this topic
#1 vunger1
vunger1
    Yamabushi
  • Chief Appliantologist
  • 76 posts
  • Flavorite Brew:maxwell house regular blend
Posted 20 November 2012 - 02:00 PM
Dryer wont turn on,has confirmed 240 volts to terminal block.
#2 RegUS_PatOff
  • 30,216 posts
Posted 20 November 2012 - 02:12 PM
how's the White Thermal Fuse on the Blower Assembly ?
(and check your Vent System)
http://www.repaircli...sp?R=154&N=2986
Thermal Fuse # 7
#3 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 20 November 2012 - 02:35 PM
thermal fuse is good ,start switch(should it complete 120volts to motor?
#4 RegUS_PatOff
  • 30,216 posts
Posted 20 November 2012 - 03:01 PM
Neutral, through the Door Switch, through the Start Switch, to the Motor ...
Wiring Sheet - W10185979.pdf
#5 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 21 November 2012 - 10:58 AM
ohmed out main and start windings, thought they were out of range.So i pulled the motor," destroying the blower fan wheel in the process",and on a whim ran 120 volt test cord (should of done this first)and the motor runs fine.Where could i be losing my power .
1)120 volts to red/white wire on start button
2)start button tests good for continuity
3)door switch good for continuity
4)thermal fuse is good
Where should I check next?
#6 RegUS_PatOff
  • 30,216 posts
Posted 21 November 2012 - 12:16 PM
no need to disconnect anything ..
Do some voltage tests while trying to run the Dryer...
#7 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 21 November 2012 - 04:09 PM
1)blue wire at thermal fuse=0 voltage / blue wire coming out of timer= 0 voltage.........bad timer? tests done with motor wiring harness unplugged from motor.
#8 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 21 November 2012 - 04:17 PM
black /L1 to timer = 0volts and also no amps(haha)
Why does my timer have to be bad?
Why couldn't it have been a bad thermal fuse,then it would cost less to repair and my profit after sale would be better(where more is better).
Just sayin...
#9 kdog
    RoughShod
  • 7,428 posts
Posted 21 November 2012 - 04:26 PM
That's never a good thing, you sure you have proper power supplied ?
Where are you touching the second probe to ground ?
#10 RegUS_PatOff
  • 30,216 posts
Posted 21 November 2012 - 04:29 PM
bad Line Cord, or no power at Wall Outlet
#11 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 21 November 2012 - 08:53 PM
oops sorry yes there is 120 volts at black wire to timer
Edited by vunger1, 21 November 2012 - 08:55 PM.
#12 kdog
    RoughShod
  • 7,428 posts
Posted 21 November 2012 - 09:04 PM
Measure voltage Black to Blue
If you see 120v
http://www.repaircli...mber=EED4400WQ0
#13 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 26 November 2012 - 08:58 PM
at the push to start button ,when i put 1 test lead on the red/white wire and 1 test lead on the neutral at the terminal block-i get 120v
but when i switch the test lead from red/white to the other side of the start switch(which is black on my dryer)i get 0v(this is with the start button pressed to complete circuit.)
So i disconnect the back wire from the start switch and test to the terminal only and(bada bing bawda boom)120v????????????
#14 RegUS_PatOff
  • 30,216 posts
Posted 26 November 2012 - 09:05 PM
... at the push to start button ,when i put 1 test lead on the red/white wire and 1 test lead on the neutral at the terminal block-i get 120v
... when i switch the test lead from red/white to the other side of the start switch(which is black on my dryer)i get 0v
are these both with the Start Button pushed ?
bad Door Switch (or wiring)
http://www.repaircli...?R=154&N=528948
#15 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 27 November 2012 - 07:10 PM
the red/white wire is 120v ? Does it matter if the button is pushed when testing this wire?
second test , yes . The button is pushed to complete circuit from red/white to black...or is it from black to red/white?
Edited by vunger1, 27 November 2012 - 09:12 PM.
#16 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 27 November 2012 - 07:14 PM
isnt the start switch just completing the nuetral circuit?
Edited by vunger1, 27 November 2012 - 07:14 PM.
#17 kdog
    RoughShod
  • 7,428 posts
Posted 28 November 2012 - 12:07 AM
If you see 120v
Yes
#18 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 06 December 2012 - 05:33 PM
I am getting 120v at push start with meter probes hooked
 1-probe to red/white
 1-probe hooked to black
Should i have voltage there?
#19 RegUS_PatOff
  • 30,216 posts
Posted 06 December 2012 - 06:51 PM
yes, if the Start Button isn't being pushed
#20 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 06 December 2012 - 08:34 PM
what wires should i test for voltage at the motor?
