estate dryer no power EED4400WQ0
26 replies to this topic
#21 kdog
    RoughShod
  • 7,428 posts
Posted 06 December 2012 - 08:55 PM
Blue and White (4&5) - did you check voltage BK-BU on timer ?
#22 vunger1
vunger1
    Yamabushi
  • Chief Appliantologist
  • 76 posts
  • Flavorite Brew:maxwell house regular blend
Posted 07 December 2012 - 10:03 AM
bk-bu at timer = ovolts
#23 suampman
suampman
    Sōhei
  • 161 posts
  • Flavorite Brew:redbridge
Posted 07 December 2012 - 10:29 AM
I have seen two of these in the last year with a high resistance between timer contacts C and B. As K-Dog said BK-BU. Good luck.
#24 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 07 December 2012 - 11:16 AM
with no voltage what would this mean?
#25 suampman
suampman
    Sōhei
  • 161 posts
Posted 07 December 2012 - 01:31 PM
You have established that you have line voltage. If this is correct, jumper your push to start switch. Turn the dryer on timed dry.Make sure door switch is closed. Put your meter probe on neutral and the other probe on timer terminal C (Bk). You should have line voltage. From there take your lead from C and put it on terminal B of the timer(LBU). Keep your other meter lead on neutral. You should still have line voltage. If not the timer contact between C and B is bad. You will need a new timer. Hope this helps.
#26 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 08 December 2012 - 10:56 AM
turned out that the LBU showed no voltage,Thanks for the help ,checking to see if I have another dryer with same timer ,I will post back once it is for sure fixed.
#27 vunger1
vunger1
    Yamabushi
  • 76 posts
Posted 08 December 2012 - 07:03 PM
Okey (replaced timer) ,dryer is working well thanks for the help guys.
