GE WASHER WONT SPIN-GE DRYER STOPS IN AUTO DRY
12 replies to this topic
#1 dryerman45
dryerman45
    Yamabushi
  • Chief Appliantologist
  • 65 posts
  • Flavorite Brew:rootbeer
Posted 21 November 2012 - 11:38 AM
Dear Master,
I have a Ge washer mod# WLSR2000G2WW.It drains but doesnt spin.It just sits there unless you manually advance timer by 0ne or two clicks,then operates normally.TIMER?
Also the same matching GE dryer mod# DLLLR23EG0WW. It works fine on Manual timer select but auto dry runs for about 15 minutes then shuts off.Moisture sensor?
Please help
Thank you,
unsei
#2 dryerman45
dryerman45
    Yamabushi
  • 65 posts
Posted 27 November 2012 - 02:52 PM
  • Posted Image
  • Chief Apprentice Appliantologist
  • Posted Image
  • 5 posts
Dear Master,
Please help
Thank you,
unsei would someone please respond to this
  • 24,692 posts
Posted 27 November 2012 - 05:27 PM
Topics merged
Dear Master,
By "operates normally" after you manually advance the timer, do you mean that it will spin? If so, then it does sound like a dead spot in the timer ==> http://www.repaircli...er=WLSR2000G2WW
  • 24,692 posts
Posted 27 November 2012 - 05:33 PM
Make sure both the elements are good. If one element is open it can cause this problem.
Element ==> http://www.repaircli...er=DLLLR23EG0WW
#5 dryerman45
dryerman45
    Yamabushi
  • 65 posts
Posted 27 November 2012 - 05:43 PM
Thank you so much,
I will go back to this nice customer with these parts and will let you know what I find.
#6 dryerman45
dryerman45
    Yamabushi
  • 65 posts
Posted 29 November 2012 - 02:36 PM
Dear Master,
Both elements are good.Have continuity on both and physically checked for breaks .Where do I go from here?
Thank you.
PS the timer did correct the washer problem
#7 kdog
    RoughShod
  • 7,433 posts
Posted 29 November 2012 - 08:16 PM
Clean out blower housing and try drying a load with vent disconnected
#8 dryerman45
dryerman45
    Yamabushi
  • 65 posts
Posted 03 December 2012 - 08:12 PM
HI,I have a GE dryer model#DLLLR23EG0WW.Works fine in timed dry,but stops when in auto dry after approx 15 minutes.I have checked both heater elements and they have continuity and are physically ok.Iam thinking the cycling thermostat may be the culprit,
Can anyone help that has seen this problem before.
Grateful,
SAMANERA
#9 kdog
    RoughShod
  • 7,433 posts
Posted 03 December 2012 - 08:23 PM
Topics merged
This Dryer ?
How did that test go with the vent disconnected ?
#10 dryerman45
dryerman45
    Yamabushi
  • 65 posts
Posted 03 December 2012 - 09:18 PM
I am going back to the customers hoiuse tommorow I will let you know.I dont understand what good it will do because the unit works fine in the timed selection.May be you could help me understand
thank you
SAMANERA
#11 kdog
    RoughShod
  • 7,433 posts
Posted 03 December 2012 - 09:37 PM
Duh, guess I missed that part, check TM-AD contacts on timer
This Manual should work
#12 RegUS_PatOff
  • 30,684 posts
Posted 03 December 2012 - 10:03 PM
... the unit works fine in the timed selection
does it actually dry the clothes within one hour ?
#13 dryerman45
dryerman45
    Yamabushi
  • 65 posts
Posted 06 December 2012 - 08:00 PM
Yes it does dry the clothes in the timed selection.
