Frigidaire range FES355DSB ate a Thanksgiving board
9 replies to this topic
#1 RedToryTy
RedToryTy
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 795 posts
  • Flavorite Brew:Guinness Stout
Posted 23 November 2012 - 08:18 AM
To the Dojo,
I roll into a customer's home to swap a Frigidaire clock to get an oven going for turkey. I installed the clock one wire at a time, remounted the clock to the cabinet, and turned the oven breaker back on. Color me surprised when, instead of Thanksgiving turkey, I got Fourth fireworks. I quickly turned off the breaker (no trip as with a direct short), and reinstalled the old, no-bake clock. I'm wanting the opinion of the Dojo: lemon clock or my screw-up?
Thanks in advance,
Tyrus
Mr. Tyrus Lee Smith
Owner-Operator, Smith's Appliance Service
701 Baldwin Falls Road
Baldwin, Georgia 30511-2108
706-778-3411
#2 RegUS_PatOff
  • 30,206 posts
Posted 23 November 2012 - 08:25 AM
need to do a visual on the Bake and Broil Elements.
Sometimes they are broken and "barely" touching the chassis,
and could cause the Controller to burn-up.
#3 certified tech group 51
  • 1,973 posts
Posted 23 November 2012 - 10:45 AM
When doing a 'no bake' situation, First thing I check for is the terminals of the bake element....That means, most of the time, pulling the unit from the wall and getting some eyes on said terminals.........More than once, I have just removed the element and found a fried terminal...That means a new terminal AND a new element ................When it is pulled from the wall you can do your hot checks of the output on the relays.......Last call Wednesday ( 11/21 ) was a 'no bake' call.............Frigidaire of course, The customer called Tuesday and said the element had failed, the office staff took the call and an element was ordered and taken..........Got there and no visual damage to the element, pulled the range and what do I spy????? A fried terminal............ I told the customer he is lucky I brought an element ( normally I do not order elements with out checking range first, ( I got a wall full of elements)................I pointed out how close the damaged wire was to the range chassis for a direct short, taking the O.C.U. with it.................. Did you visually check the element terminals and the wires????.....You could have possibly swapped the bake relays, new board to the old board... ( most common failure)....
Edited by certified tech group 51, 23 November 2012 - 10:46 AM.
#4 kdog
    RoughShod
  • 7,428 posts
Posted 24 November 2012 - 12:50 AM
Often caused by over zealous pre holiday cleaning when they lift and bend the element to clean under it, the terminal wedges itself into a part of the chassis and awaits the arrival of the unsuspecting operator who is about to experience a protein spill.
#5 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 795 posts
Posted 28 November 2012 - 08:16 PM
No fried terminals or grounded elements, no burnt wires or cabinet. Sounds like it is going to be "one of those."
Mr. Tyrus Lee Smith
706-778-3411
#6 kdog
    RoughShod
  • 7,428 posts
Posted 28 November 2012 - 08:27 PM
Check any wire looms that run next to fan shaft (if equipped)
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 1,727 posts
Posted 30 November 2012 - 12:02 AM
Where were the fireworks?  And does everything else work with the no bake timer/installed? Specifically, does the broil work? If not, does this oven have broil assist for preheating in bake mode?
I just looked at your pictures.  Ok. more brain storming....Did the original board have the same damage? If not, possibly wires crossed on board. Are boards identical? Maybe a hint can be obtained by looking at that really toasted resistor and determining what is its function.
Edited by DurhamAppliance, 30 November 2012 - 12:19 AM.
#8 DurhamAppliance
    Sho' Nuff Chozin
  • 1,727 posts
Posted 09 December 2012 - 12:48 PM
So....what happened? we are waiting
  • 24,231 posts
Posted 09 December 2012 - 03:06 PM
#10 RedToryTy
RedToryTy
    Senpai
  • PipPipPipPip
  • 795 posts
Posted 11 December 2012 - 02:14 PM
Sorry for the delay; in the Motherland (England).
No fireworks anywhere but at the fried resistor. I don't think BROIL worked on the old clock; I never tested surface element functioning without the clock. The surface units functioned fine with the old clock, though.
The original clock didn't show any damage, and the new clock layout was very different from the old. I swapped one wire at a time, i.e. P7 to P7.
The toasted resistor connected the two line wires. One line wire ohmed with 30ish ohms to ground. I pulled the top, and moved the main wire bundle until there was no continuity. I thoroughly taped the portions of the bundle I thought were making contact with the cabinet. I don't understand what was happening with the ohms I was picking up, but, after the taping up, a new clock got burnt up. The customer went shopping.
Mr. Tyrus Lee Smith
706-778-3411
