Bosch DW # SHE44C06UC/38 - FD8608 last minute takes a 1/2 hour.
5 replies to this topic
#1 Nutterman
Nutterman
    Ikkō-ikki
  • 29 posts
  • Flavorite Brew:New Castle
Posted 26 November 2012 - 09:06 PM
I haven't seen this one yet but I was hoping someone might have a good idea what to look for. Bosch dishwasher is leaving a film on the dishes and when it gets to the end of the the entire wash there will be one minute left on the display but it takes a half hour to finish.
Thanks!
Nick
#2 jumptrout
jumptrout
  • 1,124 posts
  • Flavorite Brew:Coors Light
Posted 27 November 2012 - 12:27 PM
Both problems can be a result of a bad heater circuit.
#3 kdog
    RoughShod
  • 7,428 posts
Posted 27 November 2012 - 05:20 PM
Poor circulation can cause this as well - bad circ pump, plugged with debris, or cracked/leaking upper spray tube
#4 jumptrout
jumptrout
  • 1,124 posts
Posted 27 November 2012 - 05:36 PM
What Kdog mentioned reminds me,turn the lower spray arm by hand to make certain it revolves completely without striking the feed tube to the upper arm.
I had one that had a warped lower spray arm and caused poor washing results because it would hang up at the 12 o
clock position.
Remeber to check and clean the filter as well.
#5 MrMark
MrMark
  • Chief Appliantologist
  • 7 posts
Posted 27 November 2012 - 05:55 PM
Nutterman,
There is a problem with Bosch control boards that can cause the conttrol not to finsih it's cycle. 9 times out of ten it's the problem. I replace the relay with one of adequate current capability (the original is marginal) and beef up the board. COntact me for more info BoschRepair "at" tx.rr.com
#6 kdog
    RoughShod
  • 7,428 posts
Posted 28 November 2012 - 12:17 AM
Or replace the board
http://www.repaircli...r=SHE44C06UC/38
