SAMSUNG FRONT LOAD WASHER WILL NOT SPIN
2 replies to this topic
#1 refrigerationbob
refrigerationbob
    Ikkō-ikki
  • Chief Appliantologist
  • 47 posts
Posted 27 November 2012 - 09:46 AM
I AM SERVICING A SAMSUNG MODEL # WF306LAW/XAA, IT WILL RUN NORMAL ON ALL CYCLES BUT WILL NOT SPIN THE CLOTHES OUT. THE PUMP IS CLEAR AND IT DOES PUMP ALL THE WATER OUT, ON SPIN ONLY IT WILL ROTATE APPROX 5 TURNS THEN CHIMES, THEN ROTATE IN THE OPPOSITE DIRECTION 5 TURNS AND CHIME AND CONTINUE.
I RAN A QUICK DIAGNOSIS FOR THE SPIN AND IT ONLY WILL REACH 200 RPM BEFORE IT SHUTS DOWN. ANY SUGGESTIONS, MAIN BOARD BLOWN? I DID REPLACE THE DOOR SWITCH ASSEMBLY.
  • 24,296 posts
Posted 27 November 2012 - 05:08 PM
Some other things to check: (from the service manual):
• Make sure to close the door completely.
• Perform Quick Test Mode or Quick Spin Test.
Does the washer spin? (Before the test, empty the unit inside.) If it doesn’t tumble after the above, change PCB. When the problem persists, change the motor.
• Perform Quick Test Mode or Quick Spin Test. Does the washer spin? If it does, Check Possible unbalanced load scenario in normal mode.
• Check for loose connections at PCB, Water Level Sensor, Motor, Hall Sensor Wire Harness. (CN8,CN9,CN3)
• Check motor windings resistance. (CN9 Pin1&3 = 11.6 ohms (at ±7% 20°C/68°F),
Pin1&2 = 11.6ohms (at ±7% 20°C), Pin2&3 = 11.6 ohms (at ±7% 20°C))
Service Manual ==> http://appliantology...service-manual/
Main control board ==> http://www.repaircli...er=WF306LAW XAA
Main-Control-Board-MFS-F3WLA-T0-01308450
#3 refrigerationbob
refrigerationbob
    Ikkō-ikki
  • 47 posts
Posted 30 November 2012 - 11:31 PM
PROBLEM SOLVED,
REPLACED THE MAIN BOARD AND CONTROL PANEL COMBO (PCM BOARD), UNIT IS RUNNING GREAT NOW.
