  • Announcements
DanInKansas
GE Trivection JS998SH1SS -- no loads below top respond
4 posts in this topic
Guilty plea: Have never seen or heard of a trivection before. The keypad is non responsive and nothing below the cooktop works.
Checked the TCO; it's fine. Also checked the path to power from the small relay board on the back, and it's sending power. All the fuses and TCOs seem okay. Unfortunately I did not see that the manual had been posted until after my initial visit, so I'm sure my initial diagnosis was.... unwise.
Looking at the service manual, there are a lot of possibilities, but also a lot of references to the EMI filter board.
Has anyone worked on these? Are there any known issues that came up frequently on these?
Does the control still display the time of day? If so, then either a bad touchpanel or ribbon connector between the touchpanel and ERC.
Try disconnecting the touchpanel ribbon connector from both ends and clean it up. Check it for cracks and breaks with your meter.
PMed you the minimanual for this beast.
Nay, Saumurai-san, control displays nothing at all.
Then you need to check for power to the ERC using the schematic in the minimanual I PMed you.
