whirlpool fridge model#ed5vhgxmq11
4 replies to this topic
#1 AppGuy
AppGuy
    Kohai
  • 350 posts
Posted 28 November 2012 - 08:36 PM
This fridge has the electronic defrost control in it.  It has two plugs on the defrost board.  One is the regular style defrost plug and the other is I assume the terminator signal so the board knows when to do a defrost cycle.  Question is can I just use the one plug and put a standard timer in this?  Does it have to be wired cumulative run?  I know they made this style of side by side for a long time and they used to have the old style timers in them.
Edited by AppGuy, 28 November 2012 - 08:37 PM.
#2 RegUS_PatOff
  • 30,195 posts
Posted 28 November 2012 - 09:57 PM
you could install a mechanical Defrost Timer,
BUT, the Cold Control is now wired between Orange and Red (Compressor/Fans) < that's a problem
The Red wire going (only) to the Thermostat would need to be connected to Black (Line)
#3 Budget Appliance Repair
  • 3,996 posts
Posted 29 November 2012 - 07:42 AM
I changed my refrig from a ADC to a mechanical defrost t-stat by just removing the red#3 wire from the standard defrost timer plug side and removed the white#6 wire and put it into were you removed red#3.
I put the red wire that was removed from #3 back into the molex at position #6 so that it can't contact/short on anything.
You will also need to drill a hole in the console where the defrost timer knob is if you want to be able to manually put it into defrost.
This will make it a continuous run defrost timer.
William Burk (Willie)
Eureka, CA 95501
#4 AppGuy
AppGuy
    Kohai
  • 350 posts
Posted 07 December 2012 - 01:11 PM
ok so two different methods here....  which one is the better? does it make a difference?  Grand master your saying just cut the red wire at the thermostat and tie it to the black (line) and seal off the end that runs to the evap overload etc?
#5 RegUS_PatOff
  • 30,195 posts
Posted 07 December 2012 - 01:49 PM
... and tie it to the black (line)
if there is a Black wire ...
