This may sound very simple, but... The timer stops right at rinse cycle no matter which type of load setting you choose. I did not have a schematic
and had to leave the job before opening the console to visually inspect the timer. (Three various load settings and all work except when it goes into rinse.) You can manually stop and advance the timer dial to spin, and it will complete the rest of the wash. There is no problem with the initial water
fill. Although on three different places on the dial, are all those "points of contact" for rinse activation tied into one wire(s) going to the solenoid(s) of the water valve(s)?
