Maytag MTF2656EEW refrigerator - no water to icemaker
5 replies to this topic
#1 tmfixit2
tmfixit2
  • Chief Appliantologist
  • 15 posts
  • Flavorite Brew:The local stuff
Posted 28 November 2012 - 11:24 PM
Hello, again.
Problem is with a Maytag MTF2656EEW, there is no water dispensed to the icemaker.  The water valve works out of the unit, but not when connected.  I've looked through the files and not found a repair manual.  If there is one available under this make/model or another similar unit can someone point me to it?  Or any other pointers, for that matter.
thanks in advance,
tm
#2 kdog
    RoughShod
  • 7,466 posts
Posted 28 November 2012 - 11:26 PM
That there line be frozen ?
http://www.repaircli...mber=MTF2656DEW
#3 kdog
    RoughShod
  • 7,466 posts
Posted 28 November 2012 - 11:33 PM
Icemaker manual here: http://appliantology...dular-icemaker/
See if voltage is getting to valve at end of harvest, if not - replace icemaker.
Ice-Maker-Assembly-D7824706Q-00631398.jp
#4 tmfixit2
tmfixit2
  • 15 posts
Posted 01 December 2012 - 11:46 AM
thanks for the reply and link to the manual.
This is another one of those jobs where it got taken apart, no problems found, put it back together and it works.  The valve is OK, operates with power to it.  Power to the connector and no obvious abnormal icing.  It's working right now.  We'll see what happens.
tjm
#5 Cactus Bob
Cactus Bob
    Senpai
  • PipPipPipPip
  • 553 posts
Posted 01 December 2012 - 02:25 PM
on this ice maker , the fill valve part of the cycle is a weak spot
over and over again this comes up
a few years back i installed a brand new ice maker in a fridge and the owner said it was dropping shells , so i removed it and installed a new one
returned the troubled one to the shop and installed it in a fridge in the shop , where it pumped out great cubes for 3 months and then shells again . something to do with the tension on the little fingers on the wheel
I have tried to make adjustments to these fingers but there not as easy as you might think to get right
any more i just don't mess with it , if it's new it goes back . if it's old i sell a new one
and
I never sell an ice maker without selling a new primary water valve too ! NEVER !
Edited by Cactus Bob, 01 December 2012 - 02:25 PM.
SORRY ABOUT THE SPELLING , I FIX GREAT , I DON'T SPELL WELL
#6 tmfixit2
tmfixit2
  • 15 posts
Posted 02 December 2012 - 11:19 AM
Cactus, thanks for the additional info.
It'll get a new one next time.
tjm
Edited by tmfixit2, 02 December 2012 - 11:20 AM.
