Learn how to be your own tech line...
obenourb
Sears 110.28892790 Washer Not Spinning - Jackhammer Sound
32 posts in this topic
The washer fills fine, agitator agitates, drain pump removes H20, and the at the time it is supposed to start the spin it doesn't and makes a sound like a jackhammer.  Sounds like a relay trying to repeatedly engage or something like that.  Outcome is soggy wet clothes, unhappy wife, and life is near ruin.  Any ideas out there as to what to check or what part to buy?
  I suspect either a gearcase issue or the spin tube brake cam driver. You need to take the cabinet off, bypass the lid switch and observe the clutch hub during spin. It should not spin during initial drain but should after motor pauses and starts again for spin. If it does not spin, I would remove the motor and check the drive coupling although if it is shot, it would not likely agitate either. If the coupling is ok, and the clutch hub is not spinning, you have a gearcase problem. I have a pic of where to look for the clutch hub but the site isn't allowing me to add it right now so here is the link to the pic.
http://home.comcast.net/~fairbank56/WhirlpoolClutchHub.jpg
Eric
Have you checked the coupling? Part # 285753A. That motor is direct drive, not belt driven. Those couplings break. It is an easy fix. You only need a few tools. It still pumps when the coupling is broken, which makes it nice because you don't have a tub full of water.
Remove the agitator and look at the drive block....Are the ears/tabs of the spin tube inserted fully in the drive block.........(I should learn how to post pictures) :turned:
  Here's a pic. For some reason, when I click on the image button, the window never pops up to put the link into however, the link button works fine.
Eric
Edited by RegUS_PatOff
works for me ..
Your washer has a 3 speed motor. That means there is an extra 2 wire harness that connects to the motor. If this connection is loose, the machine will pulse, buck, click, ect.. instead of spinning steady. Check it first, it's an easy no cost fix.
Nick.
If you could post a sound or vid clip that would help us point you in the right direction.
  Those two wires are for extra slow and slow speeds. If the speed select switch is set for regular or heavy duty, it's going to spin in fast speed.
Eric
I took it apart and the clip that is up inside the brake (above the clitch) came off and mangled the plastic part.  I don't know what to call the parts and would love to have an exploded diagram along with a parts description so I know what to order.  Can anyone help?
  That's the brake cam driver , part number 64194, that comes with the clutch band kit.  If you need a new clip, it's called a retaining ring, part number W10083200.
Eric
Edited by fairbank56
Thanks - that is the part.  Any idea why this might have come off?   Also - I think I would like to replace the brake pads as they look pretty worn.  The diagram you provided shows them in the picture but the part numbers are not shown.  Could you provide those part numbers too?
When I pulled the washer out to explore the problem there was a lot of dark colored dust on the floor.  It appears this came from the brake pads so while I am in the neighborhood it seems like a good idea to replace the brake pads too.  I can't find the brake parts online as I don't have any part numbers.  Any help here would be great news.
Normally that dark colored dust is from a worn rubber coupling. Make sure your coupling is good and replace if not. They are cheap.
What about this, obenourb?  You've not answered this yet.
Coupler good and is pretty new.  Best I can tell the piece came loose and was in a way that the drum would spin but I am not sure the brake cams ever disengaged the brakes.  When I look at the pads they seem pretty thin compared to the pictures I see online.
It seemed that when I tried to put the retainer clip on the brake cam driver that it wouldn't go on right.  It was very tight to the cam driver and seemed like it wasn't going up the shaft far enough to allow the retainer clip to really fit nicely into the groove.  That may be why the clip comes off (twice now).  Are there any adjustments to make or reason?
  Or you can replace the T bushing if you can get it out. This link has a good side view of the bushing so you can see where the clip goes. If this is the problem, you might as well try to get it out before buying a whole new basket drive.
Eric
But, since you can't buy the bushing seperately, you'll need the basket drive anyhow
I can't tell from the pictures or the diagram what actually holds this T-bushing on to the shaft.  Is it easy to get the old bushing off and the new one on or should I just buy the whole assembly?  Be nice to save some $ if i don't need to spend them.
Also - from the pictures there doesn't seem to be an actual groove where the retaining clip slides in.  The pictures would suggest the clip goes in behind the "T".  Have I got this correct?
  The bushing is pressed into the drive tube. The outer diameter of the drive tube is the same as the diameter of the bottom of the bushing. When the bushing is pressed into the tube, the small shoulder at the bottom of the bushing "creates" the groove. Don't know how difficult it is, never done one but would try if needed, for the small cost of a bushing.
Eric
Thanks.  I got the old bushing out with a hack saw blade pretty easy since it looks like it is made of copper and was easy to saw.  New one in the mail.  Looks like I may get out of this mess for under $35.  Compared brake pads with new ones, no significant difference, the new ones I bought are going back.
Thanks to all who helped, I think I am on the road to clean clothes once again.
Bushing is made of sintered Bronze (Olilite) - please post a link where you got the bearing from and take some pics of your journey to post for us.
