How do I remove the basket and agitator on a Maytag Bravo washer? Thanks for your help.
Ted
Edited by tedank, 29 November 2012 - 01:59 PM.
Posted 29 November 2012 - 01:59 PM
Ted
Posted 29 November 2012 - 03:46 PM
get top of washer up there is 2 clips one on each side in front use putty knife to recess the clips make sure you tape lid to top then take cover of outer tub off then take the little tab that in the middle of agitaor then take bolt off pull agitator off and the innner tub should just come up unless its stuck
Posted 29 November 2012 - 07:35 PM
model number, bravos can describe 2 completly different machines with 2 diferent ways of getting it open and removing the basket
Posted 29 November 2012 - 07:37 PM
