Speed Queen LTSA7AWN
Tub/Door boot replacement
5 replies to this topic
#1 prairiestr
prairiestr
    Sōhei
  • Chief Appliantologist
  • 189 posts
  • Flavorite Brew:Jack
Posted 29 November 2012 - 02:34 PM
This unit is a stacked washer/dryer. I need to replace the tub/door boot seal.
Question: Is it possible to replace the seal without un-stacking the dryer?
Thanks.
#2 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 01 December 2012 - 03:00 PM
Anybody work on one of these before?
#3 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 12 December 2012 - 06:42 PM
This unit is an Allaince Washer/Dryer.
I recieved the seal today and the instructions mention using "special tool 318p4" to remove the dispenser drawer.
Of course that tool is not included in the kit.
Is anyone familiar with this? :banghead:
#4 RegUS_PatOff
  • 30,232 posts
Posted 12 December 2012 - 07:37 PM
Dispenser Drawer Tool $ 4.10
http://www.appliance...-ap2400321.html
:whistling:
#5 eveready service
eveready service
    Ikkō-ikki
  • 45 posts
  • Flavorite Brew:miller high life
Posted 12 December 2012 - 08:26 PM
not needed, use a flat tip screwdriver under the tab on the bottom of tray. remove retainer wire from seal with spring in slot on panel edge,  screws from panel bottom,swing out carefully, unclip harness from panel top, rotate panel clockwise and set off to left side, now remove clamp from tub, older models will need to remove hose from valve on rear of soap tray, newer models have a worm clamp near the seal and don't come with the long hose, seal has a tab to locate in the 12 o'clock position (wetting the seal ) on tub and panel side will help with re-assy.
#6 prairiestr
prairiestr
    Sōhei
  • 189 posts
Posted 13 December 2012 - 12:56 AM
Reg and eveready,
Thanks for the info. I'll give it a try Monday. :fakenopic:
