Premier Gas Range SLK849tp01
3 replies to this topic
#1 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 03 December 2012 - 03:34 PM
This gas range has a bad spark ignition module.
I can not locate a replacement spark module.
It is a Harper Wyman module part no. 6548G.
What are my options?
#2 kdog
    RoughShod
  • 7,433 posts
Posted 03 December 2012 - 03:38 PM
http://www.frenchran...s1WiringRef.pdf
#3 Budget Appliance Repair
  • 4,032 posts
Posted 04 December 2012 - 09:26 AM
The 6548G is the base HarperWyman part# and should have 4 more numbers after it.
Should be able to use any 3+1 spark module, (3+1 means 3 surface manual spark ignitors and 1 oven re-ignite spark ignitor), (need to know what your first letter of the serial number to know if it's hot surface oven ignitor or pilot and spark ignitor in oven).
I believe it should be Premier OEM part# 2358 subs to 6548S0001
Some old numbers to look for that should be the same:
6514S0001, 1522103K, 41-514, 74549-01, R0703583
Some can be found on http://www.mypartshelf.com/ under the 6514S0001 and the other above part#'s.
http://www.premierra...parts/index.php
If you have the spark ignitor in the oven it would be a "P" series and shows ref# 34 as the spark module but ref#34 isn't listed on the parts list.
Looks like the Amana R0703583 part number is still good and available at RepairClinic:
http://www.repaircli...R0703583/231648
William Burk (Willie)
Eureka, CA 95501
#4 jumptrout
jumptrout
  • 1,192 posts
Posted 04 December 2012 - 05:32 PM
Yes,it is a P with a spark ignitor.
4 surface burners and a surface grill and the oven of course.
