jumptrout
Premier Gas Range SLK849tp01
4 posts in this topic
This gas range has a bad spark ignition module.
I can not locate a replacement spark module.
It is a Harper Wyman module part no. 6548G.
What are my options?
The 6548G is the base HarperWyman part# and should have 4 more numbers after it.
Should be able to use any 3+1 spark module, (3+1 means 3 surface manual spark ignitors and 1 oven re-ignite spark ignitor), (need to know what your first letter of the serial number to know if it's hot surface oven ignitor or pilot and spark ignitor in oven).
I believe it should be Premier OEM part# 2358 subs to 6548S0001
Some old numbers to look for that should be the same:
6514S0001, 1522103K, 41-514, 74549-01, R0703583
Some can be found on http://www.mypartshelf.com/ under the 6514S0001 and the other above part#'s.
http://www.premierrange.com/parts/index.php
If you have the spark ignitor in the oven it would be a "P" series and shows ref# 34 as the spark module but ref#34 isn't listed on the parts list.
Looks like the Amana R0703583 part number is still good and available at RepairClinic:
http://www.repairclinic.com/PartDetail/Spark-Module/R0703583/231648
2 people like this
Yes,it is a P with a spark ignitor.
4 surface burners and a surface grill and the oven of course.
2 people like this
