Whirlpool Top Load WTW6600SW
9 replies to this topic
#1 elmonducky
elmonducky
    Sōhei
  • Appliantologist
  • 128 posts
  • Flavorite Brew:Cabernet Sauvignon
Posted 04 December 2012 - 07:56 PM
OL fault code being displayed.  Usually happens at end of cycle.  Happens even with NO clothes in washer.  Replaced Main board, still no change. Tub turns freely and moves up and down freely.  Agitates, spins and drains.  Any ideas?? Only 2yrs old.
#2 RegUS_PatOff
  • 30,275 posts
Posted 04 December 2012 - 09:53 PM
Suspension Rods ?
http://www.repaircli...R=154&N=1456067
#3 nickfixit
nickfixit
  • 1,965 posts
Posted 04 December 2012 - 11:04 PM
Pull basket and look for something between tub and basket
#4 KCTBURY
KCTBURY
    Ikkō-ikki
  • Chief Appliantologist
  • 31 posts
  • Flavorite Brew:Coke
Posted 05 December 2012 - 01:51 AM
Look at suspension rods, most of the time you will see rust. Replace rods and fix leak with silicon or new tray.  Water will leak out of tray or hose.
  • 24,334 posts
Posted 05 December 2012 - 07:23 AM
Make sure the center bolt at the bottom of the machine on the rotor hasn't backed out and is tightened down all the way.
#6 elmonducky
elmonducky
    Sōhei
  • Appliantologist
  • 128 posts
Posted 06 December 2012 - 09:20 PM
Ok checked the suspension rods, no rust smooth movement.  checked center bolt, tight as a drum.  Checked between tubs, clean as a whistle.  Heres what I have noticed, when I put on rinse and spin cycle tub fills with water to about the 4th hole below the tub cover.  As soon as it stops it then drains all the water out and when it finishes draining at about 3 mins on timer is goes into a slow spin till it times out.  Then it displays a O L error code.  When it fills on rinse it never agitates it just starts draining.  I was thinking perhaps the water pressure switch but not sure.  Any input???
#7 kdog
    RoughShod
  • 7,428 posts
Posted 07 December 2012 - 12:03 AM
Pop the rotor from the bottom of tub (motor) and check for brown leaky spray from tubseal.
Video in Link:
http://www.repaircli.../280146/1175771
#8 kdog
    RoughShod
  • 7,428 posts
Posted 07 December 2012 - 12:08 AM
Manual is here
#9 elmonducky
elmonducky
    Sōhei
  • Appliantologist
  • 128 posts
Posted 07 December 2012 - 12:35 AM
I appreciate the suggestions but I dont understand the logic.  The washer goes through the complete wash cycle without a problem till it reaches the end. With no load it gives an error code indicating overload.  Why would the washer fill almost to the top of the tub on the rinse with no clothes then immediately drain without any agitation of the water?  Why would it drain the water out leaving no time for a proper spin out? 3 mins of spin could not possibly accomplish the purpose.
#10 nickfixit
nickfixit
  • 1,965 posts
Posted 07 December 2012 - 06:13 AM
Inspect the hose from the control to the tub. Maybe it is pinched flat or obstructed.
