LG Dishwasher with L.E. code? Model# LDS5811ST/01
4 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 240 posts
  • Flavorite Brew:Root Beer
Posted 05 December 2012 - 10:25 PM
LG Dishwasher with a reported code of LE. Model # LDS5811ST/01  The customer left home for several weeks and when they came back, the power was still on with this code.  She turns the power off and everything runs fine, just the power stays on.  Any idea where i should start with trouble shooting?  Thanks
#2 AlexM
AlexM
    Sōhei
  • 240 posts
#3 john63
john63
  • 1,411 posts
Posted 05 December 2012 - 10:54 PM
<<<LG Dishwasher with a reported code of LE. Model # LDS5811ST/01>>>
All LDS5811 dishwashers had flawed SUMP ASSYs.
If the SUMP ASSY has never been replaced before (under warranty or otherwise)---replace with the revised/new SUMP ASSY.
Original Sump Assy: 6871DD1002B
Revised: AJH31248604
<<<The customer left home for several weeks and when they came back, the power was still on with this code>>>
If the customer started the dishwasher---before leaving the home---this simply indicates that the WASH MOTOR either seized or began to slow down (RPMs) during the cycle---which would then trigger an "LE" error.
The error would remain active/flashing until the dishwasher is turned off.
<<<She turns the power off and everything runs fine>>>
Not uncommon in older LG dishwashers with the faulty/intermittent Wash Motor issue.
<<<just the power stays on>>>
The "LE" error keeps returning?
or...
The dishwasher never turns off ?
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
  • 24,235 posts
Posted 06 December 2012 - 08:23 AM
Sump assembly ==> http://www.repaircli...1248604/1472730
Pump-and-Motor-Assembly-AJH31248604-0075
And this video has some troubleshooting tips for the LE error and some tips on sump removal and replacement:
#5 john63
john63
  • 1,411 posts
Posted 06 December 2012 - 05:34 PM
The video shown above is very useful for the novice---however there are 2 things that should be known...
1) The model used in the video is not a "5811" model but another model which has the STEAM CLEAN option.
     On the "5811" model---there's less clutter underneath---no STEAM GENERATOR nor is there a DUAL WATER VALVE.
2) Obviously the video was made as an educational aid/guide---in a consumer's home it's not a good idea to place the dishwasher
    *on it's side*---as water will leak out from the tub onto the floor (big mess).
     Any LG dishwasher can be serviced (Sump Assy Replacement) with a full tub of water---as long as it is placed on *it's back*.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
