Samsung WF328AAW - Turning in one direction only
11 replies to this topic
#1 BenP
BenP
  • 5 posts
  • Flavorite Brew:Hoogarden
Posted 06 December 2012 - 10:54 PM
Hello everyone, first post here.
Having some issue with my June 2009 purchased Samsung WF328AAW/XAA-01 Washer.
Somehow enjoying the debugging, but much less the $$ spent trying fixing it.
Here is the gist:
- Stopped working in the middle of a wash, completely dead, no light or action on control panel, door locked.
- Open washer and checked that 120V power was getting to the main board OK.
- Removed main board assy and inspected, found burned diode and resistors around the primary side of the
transformer for the +15 and +5V.
- Ordered new replacement board from Sears, through technician during a chat session - last time I am doing
that, just want to sell you something, anything...
- Received part reference DC92-00240A - no difference on the outside with my original board.
- Installed board into washer, came back up with working control panel display
- Tried to run a cycle and got error code 3E - meaning Over-current is detected.
- Checked for the coil resistance on the brushless stator - confirmed 11.5 Ohm reading between each of the
3 motor wires.
- Entered the Quick Test Mode and ran a motor test - the motor runs in one direction but not in the other - error
code 3E showing up.
- Checked the Hall sensors voltage reading and confirmed they are both OK, going between ground and 3.75V
when rotating motor by hand.
- Used a scope on the sensors and confirmed nice 60ms  square wave on both hall sensors when motor is turing
(in one direction only).
- If the coils and hall sensors are OK, seems like the motor is not the issue.
I am a bit at a loss right now, thinking that the Main board received from Sears is not the right one.
- maybe a wrong or different firwmware, display says 9708 when running the S/W check mode.
My motor has the hall sensors attached to the stator, not removeable (same as part DC31-00049A) which, according
to John63 earlier post on this forum (thanks for great help and education BTW) is the first generation.  The magnets
have a rounded shape.
Is it possible that the replacement main board that I received from Sears is designed to work with the new
motor (DC96-01218D) and has issue with the old motor because the magnet poles are not at the expected location?
Getting the new motor is not an option as other posts mentioned that the shaft diameter of the new motor is different.
I plan to return the board back to Sears and get my money back.
Where is a good place to get a board compatible with my old generation motor - exact reference appreciated if anybody knows.
Edited by BenP, 06 December 2012 - 10:57 PM.
#2 kdog
    RoughShod
  • 7,466 posts
Posted 06 December 2012 - 11:58 PM
First up, you could have ordered parts here, this is what comes up
http://www.repaircli...F318AT0/2001646
Main-Control-Board-MFS-WF318A-T0-0126979
Secondly, try turning the basket by hand in both directions and see if it will indeed turn in both directions.
#3 john63
john63
    Dean of LG Appliantology
  • 2,211 posts
Posted 07 December 2012 - 02:08 AM
<<<I am a bit at a loss right now, thinking that the Main board received from Sears is not the right one.
- maybe a wrong or different firwmware>>>
Yes.
The best action to take---would be to contact Samsung (ask to be directed to the Parts Dept).
Give the full MODEL & SERIAL numbers---as it appears on the label of the washer.
Ask for the *correct* part number.
There were several different versions of the WF328 washer built---very confusing.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#4 BenP
BenP
  • 5 posts
Posted 07 December 2012 - 07:57 AM
Thanks for help.
- basket is turning OK by hand in both directions.  No hard point, no nothing.
- learned my lesson about ordering from Sears - key decision for me at the time was that they had the part in stock and RepairClinic was/is out.  Wife wants this thing fixed....
- I will call Samsung per your recommendation.
Will post the update.
#5 BenP
BenP
  • 5 posts
Posted 08 December 2012 - 10:18 AM
Update:
- Called Samsung part dept., gave the model and serial number, went on hold for 2 minutes, came back and said they had the part
- I asked what part number it was and they did not want to give it to me, against policy (really??)
- Explained my issue and ask how they can be sure it is the right board for my washer, answer was that's what the database says.
- Also was told that they will not accept returns on PCB (!)
- Placed the order so I could see the part number in the email confirmation
- Part number was DC92-00240A, which is exactly the same part number on the box I received from Sears Parts
- Canceled the order as I do not want another board with exactly the same reference.
Bottom line, Samsung was no help....
Questions:
- The Service Manual downloaded here (thanks for supplying it!) reference the board MFS-WF318A-T0 as the replacement part.
- It also references the DC31-00049A as the replacement motor, which is the right motor that is in my washer (the one without the hall sensors replaceable).
Safe to assume it is therefore the right board?
Anybody at RepairClinic.com has an idea on the difference between the under 2 parts?
- MFS-WF318A-T0
- DC92-00240A
Does RepairClinic.com accept returns on PCB?
#6 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 08 December 2012 - 11:03 AM
... Part number was DC92-00240A, which is exactly the same part number on the box I received from Sears Parts
... Does RepairClinic.com accept returns on PCB?
1) part number on (sealed ?) box ? ... OR may not be correct Board inside box
2) yes, if ordered from them
Parts listed at RepairClinic for Samsung WF328AAW
Sears lists (3) different WF328AAW Samsung models :wallbash:
(but as john63 mentioned, may be serial number dependent)
Main (Power) Control Board
MFS-WF318A-T0
http://www.repaircli...R=154&N=2001646
Rotor & Stator Kit
DC96-01218D
http://www.repaircli...R=154&N=2027840
Drum motor
DC31-00049A
http://www.repaircli...R=154&N=2068294
#7 BenP
BenP
  • 5 posts
Posted 08 December 2012 - 01:16 PM
Thanks for answer and help.
I will order the board from RepairClinic and give it a try.
In the meantime, going out to buy a new washer to keep wife out of my back - thinking of a LG WT4870CW
It's a top loader as the wife did not like the smell coming out of the Samsung front loader.
#8 john63
john63
  • 2,211 posts
Posted 08 December 2012 - 01:50 PM
I'd love to verify the correct part number---but I no longer have access to Samsung's password-restricted servicer website :)
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#9 certified tech group 51
  • 2,625 posts
Posted 12 December 2012 - 10:12 AM
BenR.......You are going to spend about  700 to 800 clams on an imported piece of 'soon to be repaired appliance' ?????................ How about looking into an American made appliance???...................... Speed Queen model  AWN 542 or AWN 432...Could keep a tax payers job.....Somebody has to pay for the new Affordable Health Care ...
#10 john63
john63
  • 2,211 posts
Posted 12 December 2012 - 04:04 PM
Speed Queen is good choice/well made---especially the top load washer.
Speed Queen front load washers are ideal on concrete flooring *only*. It's also somewhat small (3.3 cu ft) compared to competitor brands of front loaders today.
Front load washers---overall---clean soiled laundry better than agitatorless top load washers---as long as the correct type & amount of detergent is used.
<<<...Could keep a tax payers job.....Somebody has to pay for the new Affordable Health Care ...>>>
Taxpayer who???
Oh,you mean these nice folks :)
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#11 BenP
BenP
  • 5 posts
Posted 12 December 2012 - 08:30 PM
Update:
- Problem resolved
- I received the replacement board MFS-WF318A-T0 and it worked flawlessly.
So, in case this can help someone else:
- Old motor with the rounded magnets motor DC31-00049A needs the MFS-WF318A-T0 electronics
- New motor with the flat magnets motor DC96-01218D needs the DC92-00240A electronics
Both Sears Parts and Samsung were wrong and referenced the wrong board for my washer  WF328AAW/XAA-01
Wife is not getting the new washer (called to cancel the delivery), so no worries yet about giving money to the Chinese.
Thank you all for your help, forums like these are priceless for the DIY.
#12 kdog
    RoughShod
  • 7,466 posts
Posted 12 December 2012 - 08:56 PM
Moral of the Story: Come to Repair Clinic as they had it right all along
