795.78549.803 Bottom Freezer Kenmore (LG)
1 reply to this topic
#1 jumptrout
jumptrout
  • 1,124 posts
  • Flavorite Brew:Coors Light
Posted 07 December 2012 - 07:31 AM
This bottom freezer LG made Kenmore is dumping ice 2 to 3 times a day.
Previously it dumped often and kept the bin full.
Freezer temps are averaging around 3 degrees F.
Ice mold fills normally,fill tube is not frozen or blocked.
Are these icemakers adjustable in any way for dumping?
Does the icemaker need replacing?
  • 24,207 posts
Posted 07 December 2012 - 02:35 PM
No adjustments on this ice maker.
Fun Facts to Know and Tell:
- Minimum of 120 minutes must be allowed to make one cycle of ice after water enters the icemaker
- Minimum of 24 hours for bin to fill with ice
Here's the LG Service Bulletin on troubleshooting ice harvest problems in this unit:
LG_Refrigerator_Service_Bulletin__Troubl
You will most likely need to replace the ice maker assembly ==> http://www.repaircli...er=795.78549803
Ice-Maker-Assembly-AEQ57518202-01131157.
