Frigidaire D.W. Model# DGBD2432KF1, Spray Arms Issues
5 replies to this topic
#1 AlexM
AlexM
    Sōhei
  • Chief Appliantologist
  • 240 posts
  • Flavorite Brew:Root Beer
Posted 07 December 2012 - 01:25 PM
This Frigidaire Dishwasher Model # DGBD2432KF1, the center and top spray arm do not rotate.  The original complaint from the homeowner was that the center spray arm was hitting against the dishes in the lower rack.  It feels a little looser that I would expect.  The seal at the back of the spray assembly seams to be tight when you close the rack, the bottom spray arm works fine and the circ pump seams very strong. Replace the center spray arm and all is good?  Thanks.
#2 RegUS_PatOff
  • 30,254 posts
Posted 07 December 2012 - 01:50 PM
is there enough water in the DW ?
#3 AlexM
AlexM
    Sōhei
  • 240 posts
Posted 07 December 2012 - 02:57 PM
Seams to be plenty of water.
#4 Scottthewolf
Scottthewolf
    Senpai
  • 1,914 posts
Posted 07 December 2012 - 07:18 PM
Don't forget on most Frigidaire dishwashers they alternate the spray arms. The lower spray arm will run for awhile, the machine will pause and then the center and upper spray arm will run.  They never run at the same time.
Scott Wolf
#5 kdog
    RoughShod
  • 7,428 posts
Posted 07 December 2012 - 09:50 PM
Precision Wash: http://appliantology...wer-spray-arms/
#6 AlexM
AlexM
    Sōhei
  • 240 posts
Posted 08 December 2012 - 12:08 PM
I didn't know about the ball, that makes sense.  I think i will just order the center spray arm and see if that doesn't fix the problem.  Thanks again for the info!
