Learn Circuit Fu, the ancient lost art of appliance repair…
Sign in to follow this
Followers 0
AlexM
Frigidaire D.W. Model# DGBD2432KF1, Spray Arms Issues
6 posts in this topic
This Frigidaire Dishwasher Model # DGBD2432KF1, the center and top spray arm do not rotate.  The original complaint from the homeowner was that the center spray arm was hitting against the dishes in the lower rack.  It feels a little looser that I would expect.  The seal at the back of the spray assembly seams to be tight when you close the rack, the bottom spray arm works fine and the circ pump seams very strong. Replace the center spray arm and all is good?  Thanks.
is there enough water in the DW ?
Seams to be plenty of water.
Don't forget on most Frigidaire dishwashers they alternate the spray arms. The lower spray arm will run for awhile, the machine will pause and then the center and upper spray arm will run.  They never run at the same time.
I didn't know about the ball, that makes sense.  I think i will just order the center spray arm and see if that doesn't fix the problem.  Thanks again for the info!
Followers 0
