GE Dishwasher won't drain at the end of the cycle.
7 replies to this topic
#1 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 07 December 2012 - 08:34 PM
GE Dishwasher Model # PDWT580R30SS.  The customer's complaint was that the unit was leaking water out of the door.  I ran a few cycles and noticed that the machine would change the cycle selection on the touchpad by itself.  For instance, I selected a rinse and hold cycle and it would change itself to a normal wash cycle on it's own.   To cover all the problems I replaced the main control board, the touchpad and the water inlet valve.  After running a test cycle after I replaced all 3 of those parts, I noticed the machine failed to drain the water after the cycle was completed.  Which is weird, because this unit has a separate drain pump and the drain pump was working normally and draining the water out just fine during the cycle.  This machine uses a separate drain pump, it does not have a drain solenoid or a piston and nut assembly like on the lower line models.   This unit also drains directly into a drain, not into a garbage disposer.  It does have a high loop in the drain hose, but this drain does have an air gap.   I'm thinking the problem here might be the air gap. Any ideas?
I also notice the wash (circulation) pump has a wax motor attached to it.
http://www.repaircli...1X10235/1168301
Does anybody know what function this wax motor does here?
Scott Wolf
#2 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 08 December 2012 - 03:53 PM
Really?  101 views and nobody can help me??
Scott Wolf
#3 jumptrout
jumptrout
  • 1,122 posts
  • Flavorite Brew:Coors Light
Posted 08 December 2012 - 04:59 PM
My question is,why would you change all these parts for a leaky door?
#4 RegUS_PatOff
  • 30,188 posts
Posted 08 December 2012 - 08:59 PM
It seems only a few GE D/W models use that Wax Motor / Circulation Pump
This service manual may be similar
http://appliantology...dw9700-pdw9900/
WD21X10235
WD26X10044
http://www.repaircli...6X10044/1556553
  • 24,199 posts
Posted 08 December 2012 - 09:43 PM
Did you mean to say that it does NOT have an air gap?  If so, I would expect that to cause siphoning, not a no-drain condition.
Do you have the minimanual for this unit?  Use it to go into service mode and run the drain pump.
Other things to check:
- check the cover inlet in the basin for gookus
- remove the cover inlet and check the sump and drain outlet for gookus.
- make sure the drain pump check valve and the drain line check valve pass water in one direction only, from the pump to the drain hose; one of these could be gooked up, too.
#6 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 09 December 2012 - 01:15 AM
It DOES have an air gap.
To answer jumptrout's question.  I replaced all those parts because I could not get the unit to leak at all like the customer said.  I also replaced the control board and the touchpad because the cycle selection kept changing on it's own.  I would select rinse and hold and it would start a "normal" cycle on it's own. GE also sent all 3 parts to the customer free of charge because the unit is just a couple months out of the first year warranty.
Nobody knows what fuction the wax motor does in the wash pump???
Scott Wolf
#7 kdog
    RoughShod
  • 7,428 posts
Posted 09 December 2012 - 02:28 AM
In the manual Reg posted above, it explains the wax motor operation as a "single rack' setting
Hey, Brutha, can you spare a dime for a cuppa joe ? http://web.me.com/zenzoidman/kdog/
Le Chien Rouge
#8 Scottthewolf
Scottthewolf
    Senpai
  • 1,911 posts
Posted 09 December 2012 - 03:26 PM
thanks kdog.
Scott Wolf
